Error when creating library
The example library, Morse.h, is this:
  Morse.h - Library for flashing Morse code.
  Created by David A. Mellis, November 2, 2007.
  Released into the public domain.
#ifndef Morse_h
#define Morse_h
#include "Arduino.h"
class Morse
  public:
    Morse(int pin);
    void dot();
    void dash();
  private:
    int _pin;
#endif
I am making my own library for recursive functions. Whenever I use it in a sketch, the sketch has this compilation error:
arduino-1.6.4-windows\arduino-1.6.4\libraries\Recursives/Recursives.h:6:2: error: invalid preprocessing directive #ifindef
 #ifindef Recursives_h
Skip a little bit…
arduino-1.6.4-windows\arduino-1.6.4\libraries\Recursives/Recursives.h:21:2: error: #endif without #if
 #endif
I left out part if it, but I don’t think it matters, say, what folder arduino-1.6.4-windows is in.
What’s happening? Does anyone know how to fix it?
bbrk24:
What's happening? Does anyone know how to fix it?
change #ifindef to #ifndef
pert:
That solved part of the problem. Now it just tells me that the function I’m trying to use from the library “was not declared in this scope.”
Please provide:
  • Your library
  • Your sketch
  • Complete error message
Use code tags(</> button) for all 3.
Library header (.h):
  Recursives.h - Library containing recursive functions
  not included by default - often  with large outputs.
  Created by Billy Baker (bbrk24) on March 12th, 2016.
#ifndef Recursives_h
#define Recursives_h
class Recursives
  public:
    unsigned long ack(byte m, byte n);
    unsigned long Fib(byte iter);
    unsigned long fact(byte n);
    unsigned int gcd(unsigned int a, unsigned int b);
    unsigned int lcm(unsigned int a, unsigned int b);
#endif
Library source code (.ccp):
#include "Recursives.h"
unsigned long Recursives::ack(byte m, byte n)
  if(m==0){return n+1;}
  else{if(n==0){return ack(m-1,1);}
  else{return ack(m-1,ack(m,n-1));}}
unsigned long Recursives::Fib(byte iter) // technically primitive recursive, but whatever
  unsigned long prev = 1;
  unsigned long curr = 0;
  for(iter; iter; iter--) {
    curr = curr + prev;
    prev = curr - prev;
  return curr;
unsigned long Recursives::fact(byte n)
  if(n) {
    return fact(n - 1);
    return 1;
unsigned int Recursives::gcd(unsigned int a, unsigned int b)
  if (b)
    return gcd(b, a % b);
    return a;
unsigned int Recursives::lcm(unsigned int a, unsigned int b)
  return (a * b) / gcd(a, b); // Someone call Staples because that was easy.
Sketch (.ino):
  for (byte b = 0; b < 48; b ++) {
    Serial.println(Fib(b));
  Serial.println("\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n"); // Adds a bunch of newlines
  while(!Serial.available()){}
  byte i = 0;
  char next = Serial.read();
  while ((next - '0') >= 0 && ('9' - next) >= 0) {
    i = (i * 10) + (next - '0');
    if (next == 0 || next == -1 || next == 255) {
      delay(3);
  for (byte b = 0; b < i; b ++) {
unsigned long Fib(byte iter) { // technically primitive recursive, but whatever
    curr = curr + prev;
    prev = curr - prev;
  return curr;
Complete error message:
Arduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
sketch_mar12b.ino: In function 'void setup()':
sketch_mar12b:7: error: 'Fib' was not declared in this scope
sketch_mar12b.ino: In function 'void loop()':
sketch_mar12b:26: error: 'Fib' was not declared in this scope
  enabled in File > Preferences.
Try this sketch:
Recursives recursives;
    Serial.println(recursives.Fib(b));
  byte i = 0;
      delay(3);
    curr = curr + prev;
    prev = curr - prev;
  return curr;
And there was a missing bracket on line 34 of Recursives.cpp:
    curr = curr + prev;
    prev = curr - prev;
  return curr;
  if(n) {
    return fact(n - 1);
    return 1;
  if (b) {
    return a;
Also a couple of warnings that you might want to look into:
C:\Users\per\AppData\Local\Temp\arduino_modified_sketch_613212\sketch_mar13a.ino: In function 'void loop()':
C:\Users\per\AppData\Local\Temp\arduino_modified_sketch_613212\sketch_mar13a.ino:21:44: warning: comparison is always false due to limited range of data type [-Wtype-limits]
E:\Stuff\misc\electronics\arduino\libraries\Recursives\Recursives.cpp: In member function 'long unsigned int Recursives::Fib(byte)':
E:\Stuff\misc\electronics\arduino\libraries\Recursives\Recursives.cpp:15:11: warning: statement has no effect [-Wunused-value]
Also, note that you are supposed to install libraries to the libraries folder in your sketchbook folder instead of the libraries folder in your Arduino IDE installation folder otherwise when you update the IDE your libraries will be lost.
pert:
I never updated to or from 1.6.4.
The line " if (next == 0 || next == -1 || next == 255) {" is to detect for ascii null - 0, or sometimes it acts like -1, which wraps around to 255.
What does the line "Recursives recursives;" do?
It still doesn't work.
bbrk24:
Creates an instance of the Recursives class called recursives. It is an analog of:
int myVariable;
both are challenging names, not unlike Fib() or fact().
for what its worth, if all you want to do is add recursive functions to the base IDE, why use a Class to describe them? You then need to go through the trouble of having a class instance to operate the function... if you want to add a Fibonacci function, would you only operate it over class instance?
Just create the functions in a header file and include them in your sketch.
That is just too lame to bother replying to.
BulldogLowell:
for what its worth, if all you want to do is add recursive functions to the base IDE, why use a Class to describe them? You then need to go through the trouble of having a class instance to operate the function… if you want to add a Fibonacci function, would you only operate it over class instance?
I just want to create a library so that I don’t have to define these functions in every single sketch I make that has one of these.
That is, as far as I’m aware, what I’m trying to do. It gives me errors because it, for some reason, treats the Fib function like a variable or something and tells me I never declared it!
like this:
  if (m == 0) {
    return n + 1;
  else {
    if (n == 0) {
      return ack(m - 1, 1);
    else {
      return ack(m - 1, ack(m, n - 1));
unsigned long Fib(byte iter) // technically primitive recursive, but whatever
  for (iter; iter; iter--) {
    curr = curr + prev;
    prev = curr - prev;
  return curr;
  if (n) {
    return fact(n - 1);
    return 1;
  if (b)
    return a;
#endif
and in a sketch:
#include"Recursives.h"
int myVar = 44;
  Serial.println(Fib(myVar));
