Error(sketch_jul14c:13:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(m1, OUTPUT);
sketch_jul14c:14:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(m2, OUTPUT);
sketch_jul14c:15:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(m3, OUTPUT);
sketch_jul14c:16:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(m4, OUTPUT);
sketch_jul14c:17:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(e1, OUTPUT);
sketch_jul14c:18:8: error: expected constructor, destructor, or type conversion before '(' token
pinMode(e2, OUTPUT);
sketch_jul14c:19:1: error: 'Serial' does not name a type
/Users/wkm/Documents/Arduino/sketch_jul14c/sketch_jul14c.ino: In function 'void loop()':
sketch_jul14c:27:5: error: expected ';' before 'if'
if (serialData == '1') {
sketch_jul14c:31:5: error: 'Reverse' was not declared in this scope
Reverse motion of car else if (serialData == '2') {
sketch_jul14c:36:3: error: 'else' without a previous 'if'
else if (serialData == '3') {
sketch_jul14c:37:5: error: 'Motor' was not declared in this scope
Motor set 1 digitalWrite(m1, 0); digitalWrite(m2, 0);
sketch_jul14c:38:11: error: expected ';' before 'set'
Motor set 2 digitalWrite(m3, 0); digitalWrite(m4, 0);
sketch_jul14c:43:3: error: expected ';' before 'else'
else if (serialData == '4') {
sketch_jul14c:47:3: error: 'else' without a previous 'if'
else if (serialData == '5') {
sketch_jul14c:48:5: error: 'x' was not declared in this scope
x = 150;
sketch_jul14c:52:5: error: 'x' was not declared in this scope
x = 255;
sketch_jul14c:56:5: error: 'Motor' was not declared in this scope
Motor set 1 analogWrite(e1, x); digitalWrite(m1, 1); digitalWrite(m2, 0); //Motor set 2 analogWrite(e2, x); digitalWrite(m4, 0); digitalWrite(m3, 1);
sketch_jul14c:60:5: error: 'Motor' was not declared in this scope
Motor set 1 analogWrite(e1, x); digitalWrite(m1, 0); digitalWrite(m2, 1); //Motor set 2 analogWrite(e2, x); digitalWrite(m4, 1); digitalWrite(m3, 0);
exit status 1
That's my code
//Declare variables
char serialData;
//Declaring Pins of arduino to pins of Deek robot 2 Channel motor driver (L293D)
//Play around your driver to control the direction of motors
int m1 = 8; //connects to IN2 pin of Deek Robot motor driver -->Sets the direction
int m2 = 4; //Connects to IN1 pin of Deek Robot motor driver --> Sets the direc- tion
int e1 = 9; //Connects to EN1 pin of Deek Robot motor driver -->Sets the speed
int m3 = 7; //connects to IN3 pin of Deek Robot motor driver -->Sets the direc- tion
int m4 = 2; //Connects to IN4 pin of Deek Robot motor driver -->Sets the direc- tion
int e2 = 6; //Connects to EN2 pin of Deek Robot motor driver -->Sets the speed int x =0; //Variable to store the speed value from Python
//Setup your baudrate & arduino pins void setup()
// send data only when you receive data from python if (Serial.available() > 0)
serialData = Serial.read(); Serial.print(serialData);
128
//Forward motion of car
//Apply brakes
129
//set Speed level 1
x = 80;
//set Speed level 2
x = 150;
//set Speed level 3
else if (serialData == '6') {
x = 255;
//Turn left
else if (serialData == '7') {
//Turn right
else if (serialData == '8') {
