Error when retrieving data in fs and json
hello all I am learning how to add parameters in fs with json, data AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME successfully retrieved when reset nodemcu ESP8266 but why the data AIO_KEY not showing up please help me i am a beginner
this is my code
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//#include <Adafruit_MQTT.h>
//#include <Adafruit_MQTT_Client.h>
#include <PubSubClient.h>
#define l1 D1
#define l2 D2
#define l3 D3
#define l4 D4
#define l5 D5
#define l6 D6
#define l7 D7
#define l8 D8
#define l9 D9
//tentukan nilai default Anda di sini, jika ada nilai yang berbeda di config.json, nilai tersebut akan ditimpa.
char AIO_SERVER[40]="MQTT_SERVER";
char AIO_SERVERPORT[6] = "1883";
char AIO_USERNAME[15]= "USERNAME_MQTT";
char AIO_KEY[40] = "aio_adDK37W3yxLAr7rDJK64UUwLvLtA";
//untuk menyimpan data
bool shouldSaveConfig = false;
//memanggil ulang penyimpanan data
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
#ifdef ARDUINOJSON_VERSION_MAJOR >= 6
        DynamicJsonDocument json(1024);
        auto deserializeError = deserializeJson(json, buf.get());
        serializeJson(json, Serial);
        if ( ! deserializeError ) {
#else
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
#endif
          Serial.println("\nparsed json");
          strcpy(AIO_SERVER, json["AIO_SERVER"]);
          strcpy(AIO_SERVERPORT, json["AIO_SERVERPORT"]);
          strcpy(AIO_USERNAME, json["AIO_USERNAME"]);
          strcpy(AIO_KEY, json["AIO_KEY"]);
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_AIO_SERVER("server", "AIO SERVER", AIO_SERVER, 40);
  WiFiManagerParameter custom_AIO_SERVERPORT("port", "AIO SERVERPORT", AIO_SERVERPORT, 6);
  WiFiManagerParameter custom_AIO_USERNAME("username", "AIO USERNAME", AIO_USERNAME, 15);
  WiFiManagerParameter custom_AIO_KEY("apikey", "AIO KEY", "AIO_KEY", 40);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  wifiManager.setSTAStaticIPConfig(IPAddress(10, 0, 1, 99), IPAddress(10, 0, 1, 1), IPAddress(255, 255, 255, 0));
  //add all your parameters here
  wifiManager.addParameter(&custom_AIO_SERVER);
  wifiManager.addParameter(&custom_AIO_SERVERPORT);
  wifiManager.addParameter(&custom_AIO_USERNAME);
  wifiManager.addParameter(&custom_AIO_KEY);
  //reset settings - for testing
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.restart();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(AIO_SERVER, custom_AIO_SERVER.getValue());
  strcpy(AIO_SERVERPORT, custom_AIO_SERVERPORT.getValue());
  strcpy(AIO_USERNAME, custom_AIO_USERNAME.getValue());
  strcpy(AIO_KEY, custom_AIO_KEY.getValue());
  Serial.println("AKUN MQTT ANDA: ");
  Serial.println("\tAIO_SERVER : " + String(AIO_SERVER));
  Serial.println("\tAIO_SERVERPORT : " + String(AIO_SERVERPORT));
  Serial.println("\tAIO_USERNAME : " + String(AIO_USERNAME));
  Serial.println("\tAIO_KEY : " + String(AIO_KEY));
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
#else
    JsonObject& json = jsonBuffer.createObject();
#endif
    json["AIO_SERVER"] = AIO_SERVER;
    json["AIO_SERVERPORT"] = AIO_SERVERPORT;
    json["AIO_USERNAME"] = AIO_USERNAME;
    json["AIO_KEY"] = AIO_KEY;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    serializeJson(json, configFile);
#else
    json.printTo(configFile);
#endif
    configFile.close();
    //end save
  Serial.println("local ip");
image above before reset
after
Can you print buf after reading the file into it?
Are you saying that it appears the file is read and processed correctly, but after a reset the same file can't be read and processed correctly?
yes when I enter the parameters with wifi manager it works and can be read, but after reset the AIO_KEY part is lost
Then, like I said before: Print buf to the Serial monitor after reading it in and show us what that looks like. You should also show us what /config.json looks like.
that's the message I got on the serial monitor as I said before AIO_KEY which has been entered is lost when nodemcu restarts / resets, for json I put the parameters I input in wifimanager
that's what i want to input into json
#include "config.h"
void ReadConfigFile()
      if (configFile) {
#else
#endif
          strcpy(mqtt_server, json["mqtt_server"]);
          String port = json["mqtt_port"];
          mqtt_port = port.toInt();
          strcpy(mqtt_user, json["mqtt_user"]);
          strcpy(mqtt_password, json["mqtt_password"]);
          strcpy(mqtt_keywords1, json["mqtt_keywords1"]);
          strcpy(mqtt_keywords2, json["mqtt_keywords2"]);
          strcpy(mqtt_keywords3, json["mqtt_keywords3"]);
          strcpy(mqtt_keywords4, json["mqtt_keywords4"]);
String IpAddress2String(const IPAddress& ipAddress)
  return String(ipAddress[0]) + String(".") +\
  String(ipAddress[1]) + String(".") +\
  String(ipAddress[2]) + String(".") +\
  String(ipAddress[3])  ;
void SaveConfigFile()
    //DynamicJsonBuffer jsonBuffer;
    //JsonObject& json = jsonBuffer.createObject();
   #else
   #endif
    json["mqtt_server"] = mqtt_server;
    json["smqtt_port"] = String(smqtt_port);
    json["mqtt_user"] = mqtt_user;
    json["mqtt_password"] = mqtt_password;
    json["mqtt_keywords1"] = mqtt_keywords1;
    json["mqtt_keywords2"] = mqtt_keywords2;
    json["mqtt_keywords3"] = mqtt_keywords3;
    json["mqtt_keywords4"] = mqtt_keywords4;
    if (!configFile) {
   #else
   #endif
    configFile.close();
    //end save
void ResetSettings()
   delay(2000);
   ESP.restart();
config , thanks for your respond
