hello guys i was trying to connect my project to firebase as showed in this video Flutter & Firebase #4 - Coding the NodeMcu and Circuit Diagram - YouTube
but got this erorrs:
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\Firebase.cpp: In member function 'int FirebaseRequest::sendRequest(const string&, const string&, char*, const string&, const string&)':
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\Firebase.cpp:78:1: error: no return statement in function returning non-void [-Werror=return-type]
78 | }
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\Firebase.cpp: In member function 'void FirebaseStream::startStreaming(const string&, const string&, const string&)':
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\Firebase.cpp:91:16: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
91 | analyzeError("STREAM", status, path_with_auth);
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp:47:50: error: no matching function for call to 'begin(const char*, const char [60])'
47 | http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\NyK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
166 | bool begin(String host, uint16_t port, String uri = "/") __attribute__ ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\NyK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: conversion of argument 2 would be ill-formed:
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
| const char*
C:\Users\NyK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
167 | bool begin(String url, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\NyK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: conversion of argument 2 would be ill-formed:
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
| const char*
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
d:\Kuliah\Mata Kuliah\Internet of Things\Arduino\libraries\FirebaseArduino\src\FirebaseHttpClient_Esp8266.cpp:51:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
51 | http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
| const char*
C:\Users\NyK\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note: initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
168 | bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
cc1plus.exe: some warnings being treated as errors
exit status 1
Compilation error: exit status 1
i've installed the latest version of esp8266 and "Firebase Arduino Client Library for ESP8266 By Mobitz" but the error still occured. please help
here's my full code:
#include <ESP8266WiFi.h>
#include <SoftwareSerial.h>
#include <FirebaseArduino.h>
#include <ArduinoJson.h>
#include <ESP8266HTTPClient.h>
#include<DHT.h>
#define FIREBASE_HOST "*****firebaseio.com"
#define FIREBASE_AUTH "*****UKBpSMo07nUT8ZWYS9"
#define WIFI_SSID "******"
#define WIFI_PASSWORD "******"
#define DHTPIN D5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
bool light;
bool fan;
unsigned long previousMillis = 0;
const long interval = 10000;
pinMode(D1, OUTPUT);
WiFi.begin(WIFI_SSID,WIFI_PASSWORD);
Serial.println("Connecting..");
while (WiFi.status() != WL_CONNECTED){
Serial.print(".");
Serial.print("Connected");
Firebase.begin(FIREBASE_HOST,FIREBASE_AUTH);
dht.begin();
delay(2000);
void readDatas(){
float h=dht.readHumidity();
float t=dht.readTemperature();
Firebase.setFloat("Data/Temperature:",t);
Firebase.setFloat("Data/Humidity:",h);
light = Firebase.getBool("LightStates/switch");
Serial.println(light);
if(light==true){
digitalWrite(D6, HIGH);
if(light==false){
digitalWrite(D6, LOW);
fan = Firebase.getBool("FanStates/switch");
Serial.println(fan);
if(fan==true){
digitalWrite(D7, HIGH);
if(fan==false){
digitalWrite(D7, LOW);
if(currentMillis-previousMillis>=interval){
readDatas();
previousMillis=currentMillis;
and here is the screenshot of my firebase for better understanding:
