Error when upload =Fixed=
hi all, I am noob. I have the folloeing error when i upload, Please help. Thanks a lot.
Sulotion: uninstall IDE 1.66 completly. Install older IDE. I use 1.06.
Warning: platform.txt from core 'SparkFun AVR Boards' contains deprecated tools.avrdude.cmd.path={runtime.ide.path}/hardware/tools/avr/bin/avrdude, automatically converted to tools.avrdude.cmd.path={path}/bin/avrdude. Consider upgrading this core.
Warning: platform.txt from core 'SparkFun AVR Boards' contains deprecated tools.avrdude.config.path={runtime.ide.path}/hardware/tools/avr/etc/avrdude.conf, automatically converted to tools.avrdude.config.path={path}/etc/avrdude.conf. Consider upgrading this core.
Warning: platform.txt from core 'SparkFun AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Sketch uses 5,752 bytes (20%) of program storage space. Maximum is 28,672 bytes.
Global variables use 176 bytes of dynamic memory.
java.io.IOException: Cannot run program "{path}/bin/avrdude": CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
	at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
	at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:113)
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:157)
	at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
	at processing.app.Sketch.upload(Sketch.java:1178)
	at processing.app.Sketch.exportApplet(Sketch.java:1152)
	at processing.app.Sketch.exportApplet(Sketch.java:1124)
	at processing.app.Editor$DefaultExportHandler.run(Editor.java:2452)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
	at java.lang.ProcessImpl.start(ProcessImpl.java:137)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
	... 9 more
What does the last line say?
The last line is .......9 more
	... 9 more
You edited your first post after I had replied. That is something you are explicitly requested not to do.
dannable:
sorry about that, because when i find the last line, i found that the error message on the first post is incorrect, thats why i edit it.
Does anyone can help, please.
