Error when uploading a program using USB ASP
guys i am having a really hard time here i just recently update to the arduino 1.6.13 and suddenly i am unable to upload programs to my boards using the USB ASP, i tried uploading the DemoReel100 from FastLED and i got this error message -
Arduino: 1.6.13 (Windows 10), Board: "ATtiny, ATtiny85, 8 MHz (internal)"
In file included from C:\Users\Chris\AppData\Local\Temp\arduino_modified_sketch_790352\DemoReel100.ino:1:0:
C:\Users\Chris\Documents\Arduino\libraries\FastLED-3.1.3/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.003
 #    pragma message "FastLED version 3.001.003"
In file included from C:\Users\Chris\Documents\Arduino\libraries\FastLED-3.1.3/FastLED.h:65:0,
C:\Users\Chris\Documents\Arduino\libraries\FastLED-3.1.3/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
 #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
Sketch uses 5,798 bytes (70%) of program storage space. Maximum is 8,192 bytes.
Global variables use 295 bytes of dynamic memory.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -pattiny85 -cusbasp -Pusb -Uflash:w:C:\Users\Chris\AppData\Local\Temp\arduino_build_939068/DemoReel100.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
avrdude: Warning: cannot query manufacturer for device: No such file or directory
avrdude: Warning: cannot query product for device: No such file or directory
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5davrdude: error: could not find USB device with vid=0x16c0 pid=0x5d
c vendor='www.fischl.de' product='USBasp'
avrdude done.  Thank you.
option enabled in File -> Preferences.
It was working fine with a previous version of arduino i dont understand what happened :frowning: :confused: i really need this working by tomorrow for a party!
(deleted)
i down graded to Arduino 1.6.7 and it all went smoothly, unfortunately i need Arduino 1.6.13 for WiFi projects im trying to work on, for some reason 1.6.7 throws all kind of angry messages at me with those WiFi projects, any thoughts as to what may be causing the error message im getting?
