when i try to upload my "line tracking" program, it says: Upload error: Failed uploading: uploading error: exit status 1.
full error code:
Sketch uses 2416 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 218 bytes (10%) of dynamic memory, leaving 1830 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
no wire issues, double, triple checked. port is alright, the arduino port appeared, what should i do?
Verify your USB cable is a data cable (do you hear the system chime when you insert/remove the USB cable?).
Also verify your board and port...
- IDE >> TOOLS >> BOARD >> AVR BOARDS >> your board
- IDE >> TOOLS >> PORT >> your port
I moved your topic to an appropriate forum category @leamed.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Please enable verbose output during upload and disable verbose output during compilation. Upload your code and paste the full error message here in a new reply (using code tags as described in How to get the best out of this forum.
Some points
- Which operating system?
- Which version of the IDE?
- Which board?
- For Uno/Nano/Mega, anything connected to pins 0 and 1?
- Have you tried to upload without anything connected to the board
- Did it ever work? Did it work while you were working on your project and is now giving you problems?
