Error when uploading code to lilypad arduino
Arduino: 1.8.13 (Windows 10), Board: "LilyPad Arduino, ATmega328P"
Sketch uses 1018 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x22
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x22
option enabled in File -> Preferences.
Install the board core for your board via the IDE:
· Tools > Board > Boards Manager
· Search for "Arduino AVR Boards"
· From the drop-down menu select latest version
· Click "Install/update"
· Wait for installation to finish
· Click "Close" and restart your IDE.
. Plug your board back to the computer and select the board and port via tools.
See https://www.arduino.cc/en/Guide/Cores
Did you select the correct board? Did you select the correct port?
