Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 1784 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 185 bytes (9%) of dynamic memory, leaving 1863 bytes for local variables. Maximum is 2048 bytes.
C:\Users\sange\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\sange\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM23 -b115200 -D -Uflash:w:C:\Users\sange\AppData\Local\Temp\arduino_build_63263/test.ino.hex:iavrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Users\sange\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM23
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM23": The system cannot find the file specified.avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
The above is the error message. I'm completely new to Arduino, and I'm just trying to upload for the first time. My code is just this:
char serialData;
int pin = 7;
pinMode(pin,OUTPUT);
if(Serial.available() > 0)
serialData = Serial.read();
Serial.print(serialData);
if(serialData == '1'){
digitalWrite(pin,HIGH);}
else if(serialData == '0') {
digitalWrite(pin,LOW);}
My sketchbook location is:
C:\Users\sange\Documents\Project\Arduino
