Error when using MKR1000 with OneWire library
Hello,
I’m trying to use the OneWire and DallasTemperature libraries to get some temperature readings from a sensor. I’m using an Arduino MKR1000 with a DS18B20 temperature sensor and a 4.7kOhm resistor. My computer is running Windows 10.
I downloaded the OneWire library and placed it in my C:\Program Files(x86)\Arduino\Library directory. However, when I try to compile it with the Arduino IDE, it prints out a message that says:
C:\Program Files (x86)\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error “Please define I/O register types here”
I looked at the .h file and it seems to have a bunch of different if/elif statements checking for the platform specific I/O. Do I need to add a define statement indicating which one to use? If so, which statement should I add (there appears to be options for AVR, MK20DX128, SAM3X8E, and PIC32MX)? This is my first Arduino project ever, so please bare with me. If anybody has any suggestions to fix this problem, it’d be greatly appreciated.
To make things easier, here is the code I am trying to compile:
#include <OneWire.h>
#include <DallasTemperature.h>
/*-----( Declare Constants )-----*/
#define ONE_WIRE_BUS 16 /*-(Connect to Pin 16 )-*/
/*-----( Declare objects )-----*/
/* Set up a oneWire instance to communicate with any OneWire device*/
OneWire ourWire(ONE_WIRE_BUS);
/* Tell Dallas Temperature Library to use oneWire Library */
DallasTemperature sensors(&ourWire);
/*-----( Declare Variables )-----*/
void setup() /*----( SETUP: RUNS ONCE )----*/
/*-(start serial port to see results )-*/
Serial.println("YourDuino.com: Temperature Sensor Test Program");
Serial.println("Temperature Sensor: DS18B20");
/*-( Start up the DallasTemperature library )-*/
sensors.begin();
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
Serial.print("Requesting temperature...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Device 1 (index 0) = ");
Serial.print(sensors.getTempCByIndex(0));
Serial.println(" Degrees C");
Serial.print(sensors.getTempFByIndex(0));
Serial.println(" Degrees F");
delay(5000);
}/* --(end main loop )-- */
/* ( THE END ) */
and here is the portion of the OneWire.h file that seems to be giving problems:
// Platform specific I/O definitions
#if defined(__AVR__)
#define PIN_TO_BASEREG(pin)             (portInputRegister(digitalPinToPort(pin)))
#define PIN_TO_BITMASK(pin)             (digitalPinToBitMask(pin))
#define IO_REG_TYPE uint8_t
#define IO_REG_ASM asm("r30")
#define DIRECT_READ(base, mask)         (((*(base)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+1)) &= ~(mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+1)) |= (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+2)) &= ~(mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+2)) |= (mask))
#elif defined(__MK20DX128__)
#define PIN_TO_BASEREG(pin)             (portOutputRegister(pin))
#define PIN_TO_BITMASK(pin)             (1)
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (*((base)+512))
#define DIRECT_MODE_INPUT(base, mask)   (*((base)+640) = 0)
#define DIRECT_MODE_OUTPUT(base, mask)  (*((base)+640) = 1)
#define DIRECT_WRITE_LOW(base, mask)    (*((base)+256) = 1)
#define DIRECT_WRITE_HIGH(base, mask)   (*((base)+128) = 1)
#elif defined(__SAM3X8E__)
// Arduino 1.5.1 may have a bug in delayMicroseconds() on Arduino Due.
// http://arduino.cc/forum/index.php/topic,141030.msg1076268.html#msg1076268
// If you have trouble with OneWire on Arduino Due, please check the
// status of delayMicroseconds() before reporting a bug in OneWire!
#define PIN_TO_BASEREG(pin)             (&(digitalPinToPort(pin)->PIO_PER))
#define IO_REG_TYPE uint32_t
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (((*((base)+15)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+5)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+4)) = (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+13)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+12)) = (mask))
#ifndef PROGMEM
#define PROGMEM
#endif
#ifndef pgm_read_byte
#define pgm_read_byte(addr) (*(const uint8_t *)(addr))
#endif
#elif defined(__PIC32MX__)
#define PIN_TO_BASEREG(pin)             (portModeRegister(digitalPinToPort(pin)))
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (((*(base+4)) & (mask)) ? 1 : 0)  //PORTX + 0x10
#define DIRECT_MODE_INPUT(base, mask)   ((*(base+2)) = (mask))            //TRISXSET + 0x08
#define DIRECT_MODE_OUTPUT(base, mask)  ((*(base+1)) = (mask))            //TRISXCLR + 0x04
#define DIRECT_WRITE_LOW(base, mask)    ((*(base+8+1)) = (mask))          //LATXCLR  + 0x24
#define DIRECT_WRITE_HIGH(base, mask)   ((*(base+8+2)) = (mask))          //LATXSET + 0x28
#else
#error "Please define I/O register types here"
#endif
Would you care to edit you post and use CODE TAGS ( </> ) as the forum has a habit of changing characters unless they are inside code tags.
It also makes it much easier to work with from this side of the fence.
Edited for clarity.
This issue got resolved. The issue seemed to be that the OneWire library I had downloaded was either outdated or incomplete. I downloaded the latest version (OneWire 2.3.3) from: http://www.arduinolibraries.info/libraries/one-wire and was able to successfully get a temperature reading from the sensor.
Awesome that you responded with how you fixed it.
Always helpful for others and glad you managed to fix it by yourself.
