Error when using struct in a function
I've got the following bit of code (simplified for the problem):
struct myStruct {
  double a;
  double b;
myStruct aStruct = {0,1.5};
//double getA( myStruct &aStruct) {
//  return aStruct.a;
  Serial.println("Starting");
  double printMe;
 // printMe = getA(aStruct);
  Serial.println(printMe);
Like this it runs, so the initialization part of the struct works fine, but when I uncomment the function getA() (and in the loop()), I get the following error:
postUp:-1: error: 'myStruct' was not declared in this scope
postUp:-1: error: 'aStruct' was not declared in this scope
postUp.cpp: In function 'double getA(myStruct&)':
postUp:7: error: 'double getA(myStruct&)' redeclared as different kind of symbol
postUp:-1: error: previous declaration of 'double getA'
postUp.cpp: In function 'void loop()':
postUp:20: error: 'getA' cannot be used as a function
Can anyone shed some light on this? I can't see where I could possibly be redeclaring anything....
Try using * instead of & and -> instead of .:
double getA(struct myStruct *aStruct) {
  return aStruct->a;
These two messages should give you a clue. The Arduino IDE creates function prototypes for all functions. It fails to do so properly for functions that use reference parameters. So, you need to define the function prototype even though you define the function before you reference it. Doing so will prevent the IDE from trying to "help" you define it.
Thanks,
found the problem through Majenko's snippet, though it's actually something else: need to declare struct in the function as
double getA(struct myStruct &aStruct) {
  return aStruct.a;
I had written getA(myStruct &aStruct) :{|
Cheers,
lifesayko
lifesayko:
I much prefer to declare a typedef for the struct type so that you can treat it just like any other type.
As the .ino is essentially a cpp and GCC is C++, not C. Typedef makes no difference as a named struct is its type-name also ( even an un-named struct is still an anonymous type ).
The problem may be how the IDE pre-processes your sketch and generates prototypes. This creates problems with functions that use user-defined types or enumerations.
If you define your class or structure in a separate tab as a .h file, then #include that in your main or other tab, you can use it.
I.e.: main sketch tab:
#include "foo.h"
return aStruct.a;
  double printMe;
foo.h tab:
struct myStruct {
  double a;
  double b;
compiles.
