Tryin to use arduino to program my trinket mo with a rotary encoder to control 2 16 pixel rings. I keep getting error on a test code i copied from Arduino Examples | Adafruit Rotary Trinkey | Adafruit Learning System
'NUM_NEOPIXEL' was not declared in this scope
Heres the code
#include "Adafruit_FreeTouch.h"
#include <RotaryEncoder.h>
// Create the neopixel strip with the built in definitions NUM_NEOPIXEL and PIN_NEOPIXEL
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_NEOPIXEL, PIN_NEOPIXEL, NEO_GRB + NEO_KHZ800);
int16_t neo_brightness = 20; // initialize with 20 brightness (out of 255)
RotaryEncoder encoder(PIN_ENCODER_A, PIN_ENCODER_B, RotaryEncoder::LatchMode::FOUR3);
// This interrupt will do our encoder reading/checking!
void checkPosition() {
encoder.tick(); // just call tick() to check the state.
uint8_t wheel_offset = 99;
int last_rotary = 0;
//while (!Serial);
// start neopixels
strip.begin();
strip.setBrightness(neo_brightness);
strip.show(); // Initialize all pixels to 'off'
attachInterrupt(PIN_ENCODER_A, checkPosition, CHANGE);
attachInterrupt(PIN_ENCODER_B, checkPosition, CHANGE);
// set up the encoder switch, which is separate from the encoder
pinMode(PIN_ENCODER_SWITCH, INPUT_PULLDOWN);
// read encoder
int curr_rotary = encoder.getPosition();
RotaryEncoder::Direction direction = encoder.getDirection();
if (curr_rotary != last_rotary) {
Serial.print("Encoder value: ");
Serial.print(curr_rotary);
Serial.print(" direction: ");
Serial.print((int)direction);
// behavior differs if switch is pressed
if (!digitalRead(PIN_ENCODER_SWITCH)) {
// update color
if (direction == RotaryEncoder::Direction::CLOCKWISE) {
wheel_offset++;
if (direction == RotaryEncoder::Direction::COUNTERCLOCKWISE) {
wheel_offset--;
// update brightness
neo_brightness += 10;
neo_brightness -= 10;
// ranges between 0 and 255
if (neo_brightness > 255) neo_brightness = 255;
if (neo_brightness < 0) neo_brightness = 0;
Serial.print(" wheel color: ");
Serial.print(wheel_offset);
Serial.print(" brightness: ");
Serial.println(neo_brightness);
last_rotary = curr_rotary;
// update pixels!
strip.setPixelColor(0, Wheel(wheel_offset));
strip.show();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
