Error when writing to arduino using the WebServer ethernet example.
Can't figure out why it gives me this long list of errors:
In file included from E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:14,
                 from E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:10:
E:\Programming\Arduino\Arduino\libraries\Spi/SPI.h:36: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'SPIClass'
E:\Programming\Arduino\Arduino\libraries\Spi/SPI.h:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'SPI'
E:\Programming\Arduino\Arduino\libraries\Spi/SPI.h:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Spi/SPI.h:62: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Spi/SPI.h:66: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:10:
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:18: error: redefinition of typedef 'SOCKET'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/types.h:137: error: previous declaration of 'SOCKET' was here
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:49: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'SnMR'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:87: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'SnIR'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:96: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'SnSR'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:115: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'IPPROTO'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:129: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'W5100Class'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:323: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'W5100'
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:325: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:329: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:333: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:337: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:341: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:345: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:349: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:353: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:357: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:361: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:365: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:369: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:373: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\/w5100.h:377: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'socket':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: 'Sn_MR_TCP' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: (Each undeclared identifier is reported only once
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: for each function it appears in.)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: 'Sn_MR_UDP' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: 'Sn_MR_IPRAW' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: 'Sn_MR_MACRAW' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:31: error: 'Sn_MR_PPPOE' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:43: error: 'Sn_CR_OPEN' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'close':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:71: error: 'Sn_CR_CLOSE' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'listen':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:101: error: 'SOCK_INIT' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:103: error: 'Sn_CR_LISTEN' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'connect':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:155: error: 'Sn_CR_CONNECT' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'disconnect':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:175: error: 'Sn_CR_DISCON' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c: In function 'send':
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:209: error: 'SOCK_ESTABLISHED' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:209: error: 'SOCK_CLOSE_WAIT' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:221: error: 'Sn_CR_SEND' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:232: error: 'Sn_IR_SEND_OK' undeclared (first use in this function)
E:\Programming\Arduino\Arduino\libraries\Ethernet\utility\socket.c:236: error: 'SOCK_CLOSED' undeclared (first use in this function)
Any ideas?
Your errors may depend on your code and the IDE you are using.
zoomkat: Your errors may depend on your code and the IDE you are using.
Loaded the example from the Arduino 022, and just pushed Upload. Didn't do any changes to the code at all. Seems to be something with the Ethernet library, it won't compile any examples at all :S
Did you select a board type? Is it the right one? What OS are you on?
Too much information is better than too little. Fee free to volunteer more than you think we need to know.
PaulS:
Loaded the example from the Arduino 022, and just pushed Upload. Didn’t do any changes to the code at all.
Windows 7 x64
Arduino 022 just downloaded.
Did select the correct board type, just tried the blink example and it works fine =)
EDIT:
Even this won’t compile :S
#include <SPI.h>
#include <Ethernet.h>
Even this won't compile :S
I'm pretty sure you saw something more than "Nope, not going to compile that!".
PaulS:
I’m pretty sure you saw something more than “Nope, not going to compile that!”.
Yes, of course sorry was a littlebit quick there:
Thats the errors I’m geting using this code:
#include <SPI.h>
I get:
Binary sketch size: 450 bytes (of a 30720 byte maximum)
So, there is something wrong with one of the libraries that you downloaded.
Post your SPI.h and Ethernet.h files, for comparison.
PaulS: I get:
Ethernet.h: http://pastebin.com/sCiRRSa3 SPI.h: http://pastebin.com/MX3ZfVPa
They look just like mine. Since you are getting different results, perhaps it's time to reveal what board type you are compiling for.
PaulS: They look just like mine. Since you are getting different results, perhaps it's time to reveal what board type you are compiling for.
Arduino Diecimila
I compiled the webserver included in the 0022 IDE without any errors. When in doubt, reboot!
I select that board type and compiled just fine. Perhaps you need to uninstall and reinstall the Arduino IDE.
PaulS: I select that board type and compiled just fine. Perhaps you need to uninstall and reinstall the Arduino IDE.
This is strange, I decided to try and unpack the Arduino IDE one more time. But instead of overwriting the files, I deleted the old ones first. And now it's compiling ! Thanks for all the great help, and I'm sorry for not trying this in the first place :P
You have nothing to apologize for. Re-installing the IDE was the last thing you should have had to do. Windows needs to figure out a better balance between paranoia (nobody can alter any file) and don't-give-a-damn (anybody can overwrite any file). Unix figured it out a long time ago.
