Hello Everyone,
I was trying to send notifications from my esp32 to Telegram
Environment:
Windows 10 Home Single Language
Arduino IDE
Code:
* Push Notificaiton Demo *
* Using IFTTT and Telegram to send alerts to your phone *
* Telegram Library: *
* https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot *
* IFTTT Maker Library: *
* https://github.com/witnessmenow/arduino-ifttt-maker *
* By Brian Lough *
//Including the two libraries
#include <UniversalTelegramBot.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
//------- WiFi Settings -------
char ssid[] = "SSID"; // your network SSID (name)
char password[] = "PASSWORD"; // your network key
#define TELEGRAM_BUTTON_PIN 4
// ------- Telegram config --------
#define BOT_TOKEN "" // your Bot Token (Get from Botfather)
#define CHAT_ID "" // Chat ID of where you want the message to go (You can use MyIdBot to get the chat ID)
// SSL client needed for both libraries
WiFiClientSecure client;
UniversalTelegramBot bot(BOT_TOKEN, client);
String ipAddress = "";
volatile bool telegramButtonPressedFlag = false;
// Initlaze the buttons
pinMode(TELEGRAM_BUTTON_PIN, INPUT);
// NOTE:
// It is important to use interupts when making network calls in your sketch
// if you just checked the status of te button in the loop you might
// miss the button press.
attachInterrupt(TELEGRAM_BUTTON_PIN, telegramButtonPressed, RISING);
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// Attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
IPAddress ip = WiFi.localIP();
Serial.println(ip);
ipAddress = ip.toString();
void telegramButtonPressed() {
Serial.println("telegramButtonPressed");
int button = digitalRead(TELEGRAM_BUTTON_PIN);
if(button == HIGH)
telegramButtonPressedFlag = true;
return;
void sendTelegramMessage() {
String message = "SSID: ";
message.concat(ssid);
message.concat("\n");
message.concat("IP: ");
message.concat(ipAddress);
if(bot.sendMessage(CHAT_ID, message, "Markdown")){
Serial.println("TELEGRAM Successfully sent");
if ( telegramButtonPressedFlag ) {
sendTelegramMessage();
So this is the code.
While i was compiling it i got an error
Error:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Angad\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Angad\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Angad\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10815 -build-path C:\Users\Angad\AppData\Local\Temp\arduino_build_678539 -warnings=none -build-cache C:\Users\Angad\AppData\Local\Temp\arduino_cache_847771 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo\PushNotificaitonDemo.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Angad\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Angad\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Angad\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10815 -build-path C:\Users\Angad\AppData\Local\Temp\arduino_build_678539 -warnings=none -build-cache C:\Users\Angad\AppData\Local\Temp\arduino_cache_847771 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo\PushNotificaitonDemo.ino
Using board 'esp32' from platform in folder: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
Using core 'esp32' from platform in folder: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
cmd /c if exist "C:\\Users\\Angad\\Downloads\\push-notifications-arduino-esp8266-master\\PushNotificaitonDemo\\partitions.csv" copy /y "C:\\Users\\Angad\\Downloads\\push-notifications-arduino-esp8266-master\\PushNotificaitonDemo\\partitions.csv" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\partitions.csv"
cmd /c if not exist "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\partitions.csv" copy "C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\tools\\partitions\\default.csv" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\partitions.csv"
Detecting libraries used...
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o nul
Alternatives for UniversalTelegramBot.h: [UniversalTelegramBot@1.1.0]
ResolveLibrary(UniversalTelegramBot.h)
-> candidates: [UniversalTelegramBot@1.1.0]
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o nul
Alternatives for ArduinoJson.h: [ArduinoJson@5.13.5]
ResolveLibrary(ArduinoJson.h)
-> candidates: [ArduinoJson@5.13.5]
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.0 WiFi@1.2.7]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.0 WiFi@1.2.7]
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o nul
Alternatives for WiFiClientSecure.h: [WiFiClientSecure@1.0]
ResolveLibrary(WiFiClientSecure.h)
-> candidates: [WiFiClientSecure@1.0]
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFiClientSecure\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src\UniversalTelegramBot.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\ETH.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFiClientSecure\src\WiFiClientSecure.cpp
Using cached library dependencies for file: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFiClientSecure\src\ssl_client.cpp
Generating function prototypes...
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFiClientSecure\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10815 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\esp32" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\UniversalTelegramBot\\src" "-IC:\\Users\\Angad\\OneDrive\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFiClientSecure\\src" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp" -o "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp.o"
Compiling libraries...
Compiling library "UniversalTelegramBot"
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o
Compiling library "ArduinoJson"
Compiling library "WiFi"
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\ETH.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFi.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiAP.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiMulti.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiScan.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiSTA.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiUdp.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiServer.cpp.o
Compiling library "WiFiClientSecure"
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o
Using previously compiled file: C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\ssl_client.cpp.o
Compiling core...
Using precompiled core: C:\Users\Angad\AppData\Local\Temp\arduino_cache_847771\core\core_cdeccd3815e42438f3b0f04ef320ac60.a
Linking everything together...
"C:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc" -nostdlib "-LC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/lib" "-LC:\\Users\\Angad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/ld" -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\sketch\\PushNotificaitonDemo.ino.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\UniversalTelegramBot\\UniversalTelegramBot.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\ETH.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiClient.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiServer.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFi\\WiFiUdp.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFiClientSecure\\WiFiClientSecure.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539\\libraries\\WiFiClientSecure\\ssl_client.cpp.o" "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_cache_847771\\core\\core_cdeccd3815e42438f3b0f04ef320ac60.a" -lgcc -lapp_trace -llibsodium -lbt -lesp-tls -lmdns -lconsole -ljsmn -lesp_ringbuf -lpthread -ldriver -ldetection -lsoc -lc -lmesh -lwpa2 -ljson -ldl -lwear_levelling -lmicro-ecc -lcoexist -lface_detection -lnvs_flash -lwifi_provisioning -lfr -lnghttp -lesp32 -lnet80211 -lesp_http_server -ltcp_transport -llog -lespnow -lhal -lmqtt -lesp_websocket_client -lesp_http_client -lvfs -lbtdm_app -lapp_update -lpe -lprotocomm -lwps -lsdmmc -lesp_adc_cal -lwpa -lefuse -lcoap -lsmartconfig -limage_util -lspiffs -lulp -lunity -lface_recognition -lesp_https_server -lethernet -lspi_flash -lpp -lexpat -lfatfs -ltcpip_adapter -llwip -lcxx -lfreertos -lesp32-camera -lmbedtls -ldetection_cat_face -lm -lc_nano -lesp_event -lnewlib -lcore -lopenssl -lsmartconfig_ack -lwpa_supplicant -lbootloader_support -lasio -lesp_https_ota -lod -lespcoredump -lheap -lrtc -lprotobuf-c -lfb_gfx -lfreemodbus -lfd -lphy -lxtensa-debug-module -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\\Users\\Angad\\AppData\\Local\\Temp\\arduino_build_678539/PushNotificaitonDemo.ino.elf"
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5/tools/sdk/lib\libesp32.a(cpu_start.o):(.literal.main_task+0x14): undefined reference to `app_main'
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5/tools/sdk/lib\libesp32.a(cpu_start.o): In function `main_task':
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/cpu_start.c:545: undefined reference to `app_main'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\ssl_client.cpp.o: In function `start_ssl_client(sslclient_context*, char const*, unsigned int, int, char const*, char const*, char const*, char const*, char const*, bool)':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFiClientSecure\src/ssl_client.cpp:413: undefined reference to `IPAddress::IPAddress(unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\ssl_client.cpp.o: In function `_GLOBAL__sub_I_pers':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/IPAddress.h:94: undefined reference to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_ssid+0x1c): undefined reference to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_ssid+0x20): undefined reference to `String::String(char const*)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_ssid+0x24): undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o: In function `_GLOBAL__sub_I_ssid':
C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo/PushNotificaitonDemo.ino:33: undefined reference to `String::String(char const*)'
C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo/PushNotificaitonDemo.ino:33: undefined reference to `String::~String()'
C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo/PushNotificaitonDemo.ino:34: undefined reference to `String::String(char const*)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o: In function `_GLOBAL__sub_D_ssid':
C:\Users\Angad\Downloads\push-notifications-arduino-esp8266-master\PushNotificaitonDemo/PushNotificaitonDemo.ino:34: undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o: In function `UniversalTelegramBot::~UniversalTelegramBot()':
C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.h:49: undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\sketch\PushNotificaitonDemo.ino.cpp.o:C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.h:36: more undefined references to `String::~String()' follow
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o:(.literal._ZN20UniversalTelegramBotC2E6StringR6Client+0x0): undefined reference to `String::operator=(String const&)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o: In function `telegramMessage::telegramMessage()':
C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.cpp:415: undefined reference to `String::String(char const*)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o:C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.cpp:415: more undefined references to `String::String(char const*)' follow
C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.cpp:415: undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o:C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.cpp:415: more undefined references to `String::~String()' follow
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o: In function `UniversalTelegramBot::UniversalTelegramBot(String, Client&)':
C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot\src/UniversalTelegramBot.cpp:415: undefined reference to `String::operator=(String const&)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\UniversalTelegramBot\UniversalTelegramBot.cpp.o: In function `_GLOBAL__sub_I__ZN20UniversalTelegramBotC2E6StringR6Client':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o:(.literal._ZN10WiFiClient7connectE9IPAddresst+0x0): undefined reference to `vtable for IPAddress'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o:(.literal._ZN10WiFiClient7connectEPKcti+0x0): undefined reference to `IPAddress::IPAddress(unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o:(.literal._ZN10WiFiClient10setTimeoutEj+0x8): undefined reference to `Stream::setTimeout(unsigned long)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o: In function `WiFiClient::connect(char const*, unsigned short, int)':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiClient.cpp:582: undefined reference to `IPAddress::IPAddress(unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o: In function `WiFiClient::setTimeout(unsigned int)':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiClient.cpp:582: undefined reference to `Stream::setTimeout(unsigned long)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o: In function `_GLOBAL__sub_I__ZN10WiFiClientC2Ev':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiClient.cpp:582: undefined reference to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o:(.rodata._ZTV10WiFiClient[vtable for WiFiClient]+0x2c): undefined reference to `Stream::readBytes(char*, unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiClient.cpp.o:(.rodata._ZTV10WiFiClient[vtable for WiFiClient]+0x34): undefined reference to `Stream::readString()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiSTA.cpp.o: In function `_GLOBAL__sub_I__ZN12WiFiSTAClass14_autoReconnectE':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiSTA.cpp:74: undefined reference to `String::String(char const*)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiSTA.cpp.o: In function `_GLOBAL__sub_D__ZN12WiFiSTAClass14_autoReconnectE':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiSTA.cpp:74: undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o:(.literal._ZN16WiFiClientSecure4peekEv+0x0): undefined reference to `Stream::timedRead()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o:(.literal._ZN16WiFiClientSecure7connectE9IPAddresstPKcS2_S2_+0x0): undefined reference to `IPAddress::toString() const'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o: In function `WiFiClientSecure::peek()':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/Stream.h:105: undefined reference to `Stream::timedRead()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o: In function `WiFiClientSecure::connect(IPAddress, unsigned short, char const*, char const*, char const*)':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/Stream.h:105: undefined reference to `IPAddress::toString() const'
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/Stream.h:105: undefined reference to `String::~String()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o: In function `WiFiClientSecure::connect(IPAddress, unsigned short, char const*, char const*)':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o: In function `_GLOBAL__sub_I__ZN16WiFiClientSecureC2Ev':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/Stream.h:105: undefined reference to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)'
Multiple libraries were found for "WiFi.h"
Used: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Not used: C:\Users\Angad\OneDrive\Documents\Arduino\libraries\WiFi
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o:(.rodata._ZTV16WiFiClientSecure[vtable for WiFiClientSecure]+0x2c): undefined reference to `Stream::readBytes(char*, unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFiClientSecure\WiFiClientSecure.cpp.o:(.rodata._ZTV16WiFiClientSecure[vtable for WiFiClientSecure]+0x34): undefined reference to `Stream::readString()'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiGeneric.cpp.o:(.literal._ZL23wifi_dns_found_callbackPKcPK7ip_addrPv+0x4): undefined reference to `IPAddress::operator=(unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiGeneric.cpp.o: In function `wifi_dns_found_callback(char const*, ip_addr const*, void*)':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiGeneric.cpp:200: undefined reference to `IPAddress::operator=(unsigned int)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiGeneric.cpp.o: In function `WiFiGenericClass::hostByName(char const*, IPAddress&)':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiGeneric.cpp.o: In function `_GLOBAL__sub_I__Z14postToSysQueueP19system_prov_event_t':
C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiGeneric.cpp:200: undefined reference to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\ETH.cpp.o: In function `_GLOBAL__sub_I__ZN8ETHClassC2Ev':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFi.cpp.o: In function `_GLOBAL__sub_I__ZN9WiFiClass9printDiagER5Print':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiAP.cpp.o: In function `_GLOBAL__sub_I__ZN11WiFiAPClass6softAPEPKcS1_iii':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiMulti.cpp.o: In function `_GLOBAL__sub_I__ZN9WiFiMultiC2Ev':
C:\Users\Angad\AppData\Local\Temp\arduino_build_678539\libraries\WiFi\WiFiScan.cpp.o:C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/IPAddress.h:94: more undefined references to `IPAddress::IPAddress(unsigned char, unsigned char, unsigned char, unsigned char)' follow
collect2.exe: error: ld returned 1 exit status
Using library UniversalTelegramBot at version 1.1.0 in folder: C:\Users\Angad\OneDrive\Documents\Arduino\libraries\UniversalTelegramBot
Using library ArduinoJson at version 5.13.5 in folder: C:\Users\Angad\OneDrive\Documents\Arduino\libraries\ArduinoJson
Using library WiFi at version 1.0 in folder: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Using library WiFiClientSecure at version 1.0 in folder: C:\Users\Angad\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFiClientSecure
exit status 1
Error compiling for board ESP32 Dev Module.
I know its a long one
Please help me.
Regards,
Angad Singh
