Hi all!
I'm facing a problem while compiling the rosserial IrRanger example that is provided in arduino.
Code as below;
#include <ros.h>
#include <ros/time.h>
#include <sensor_msgs/Range.h>ros::NodeHandle nh;
sensor_msgs::Range range_msg;
ros::Publisher pub_range( "range_data", &range_msg);const int analog_pin = 0;
unsigned long range_timer;/*
- getRange() - samples the analog input from the ranger
- and converts it into meters.
float getRange(int pin_num){
int sample;
// Get data
sample = analogRead(pin_num)/4;
// if the ADC reading is too low,
// then we are really far away from anything
if(sample < 10)
return 254; // max range
// Magic numbers to get cm
sample= 1309/(sample-3);
return (sample - 1)/100; //convert to meters
}char frameid[] = "/ir_ranger";
nh.initNode();
nh.advertise(pub_range);range_msg.radiation_type = sensor_msgs::Range::INFRARED;
range_msg.header.frame_id = frameid;
range_msg.field_of_view = 0.01;
range_msg.min_range = 0.03;
range_msg.max_range = 0.4;}
// publish the range value every 50 milliseconds
// since it takes that long for the sensor to stabilize
if ( (millis()-range_timer) > 50){
range_msg.range = getRange(analog_pin);
range_msg.header.stamp = nh.now();
pub_range.publish(&range_msg);
range_timer = millis() + 50;
nh.spinOnce();
Error as below ;
In file included from /home/gerald/sketchbook/libraries/ros_lib/ros.h:39:0,
from IrRanger.cpp:7:
/home/gerald/sketchbook/libraries/ros_lib/ArduinoHardware.h:38:22: fatal error: WProgram.h: No such file or directory
compilation terminated.
