"Arduino: 1.5.6-r2 (Windows 8), Board: "Arduino NG or older, ATmega8"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp:32:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\/HardwareSerial_private.h: In member function 'void HardwareSerial::_rx_complete_irq()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\/HardwareSerial_private.h:98: error: 'UPE' was not declared in this scope
enabled in File > Preferences.""
I have the same problem, the old (1.05) IDE works but unable to use may USBasp programmer (it wants to use it trough a COM port instead of USB directly).
The Boot Code updated anyway without any issues using avrdude by hand (Kubuntu 14.04 AMD64)
The IC is ATMega8A - and reading the manual it has "Programmable Serial USART" - if You mean it.
I've found this remark in HardwareSerial_private.h at line 36:
// On ATmega8, the uart and its bits are not numbered, so there is no TXC0 etc.
I think there´s a new bug in 1.5.6r2.
I tried to compile the blink example for atmega8 and it gave same message as yours.
I compiled in the 1.5.5r2 and it´s ok.
In 1.5.6r2 i compiled the same code for arduino uno and it´s ok.
I tried in the windows 7 and windows 8.1 and the result was the same.
Let me know if with you this occurs the same.
I am having the same problem only for the atmega16.
I have accommodated the PE/UPE bug as far as I can tell by using
however I a still getting errors when compiling for atmega16
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial_private.h: In member function 'void HardwareSerial::_rx_complete_irq()':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial_private.h:107: error: 'rx_buffer_index_t' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial_private.h:107: error: expected `;' before 'i'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial_private.h:113: error: 'i' was not declared in this scope
