Arduino: 1.8.19 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Navid.H\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Navid.H\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Navid.H\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794 -warnings=none -build-cache C:\Users\Navid.H\AppData\Local\Temp\arduino_cache_304427 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\UDPRECIEVER_SERVER__Final_With_Internet.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Navid.H\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Navid.H\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Navid.H\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794 -warnings=none -build-cache C:\Users\Navid.H\AppData\Local\Temp\arduino_cache_304427 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mkspiffs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.mklittlefs-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.3-gcc10.3-9bcba0b.path=C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b -verbose C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\UDPRECIEVER_SERVER__Final_With_Internet.ino
Using board 'd1_mini' from platform in folder: C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Using core 'esp8266' from platform in folder: C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1
Detecting libraries used...
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\sketch\UDPRECIEVER_SERVER__Final_With_Internet.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\sketch\UDPRECIEVER_SERVER__Final_With_Internet.ino.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\BearSSLHelpers.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiGratuitous.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\WiFiClient.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\WiFiClientSecureBearSSL.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\WiFiServer.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\WiFiServerSecureBearSSL.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\WiFiUdp.cpp" -o nul
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src\enable_wifi_at_boot_time.cpp" -o nul
Generating function prototypes...
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\sketch\UDPRECIEVER_SERVER__Final_With_Internet.ino.cpp" -o "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" "C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/signing.py" --mode header --publickey "C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet/public.key" --out "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core/Updater_Signing.h"
"C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.3-gcc10.3-9bcba0b/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/lwip2/include" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"" -DFLASHMODE_DIO -DESP8266 "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\variants\d1_mini" "-IC:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src" "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\sketch\UDPRECIEVER_SERVER__Final_With_Internet.ino.cpp" -o "C:\Users\Navid.H\AppData\Local\Temp\arduino_build_980794\sketch\UDPRECIEVER_SERVER__Final_With_Internet.ino.cpp.o"
C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\UDPRECIEVER_SERVER__Final_With_Internet.ino: In function 'void setup()':
UDPRECIEVER_SERVER__Final_With_Internet:71:27: error: conversion from 'IPAddress' to 'ip_addr*' is ambiguous
71 | dhcps_set_DNS(WiFi.dnsIP());
In file included from C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi\src/ESP8266WiFi.h:31,
from C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\UDPRECIEVER_SERVER__Final_With_Internet.ino:1:
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:81:9: note: candidate: 'IPAddress::operator uint32_t() const' (near match)
81 | operator uint32_t() const { return isV4()? v4(): (uint32_t)0; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:81:9: note: no known conversion from 'uint32_t' {aka 'unsigned int'} to 'ip_addr*'
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:82:9: note: candidate: 'IPAddress::operator uint32_t()' (near match)
82 | operator uint32_t() { return isV4()? v4(): (uint32_t)0; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:82:9: note: no known conversion from 'uint32_t' {aka 'unsigned int'} to 'ip_addr*'
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:83:9: note: candidate: 'IPAddress::operator u32_t() const' (near match)
83 | operator u32_t() const { return isV4()? v4(): (u32_t)0; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:83:9: note: no known conversion from 'u32_t' {aka 'long unsigned int'} to 'ip_addr*'
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:84:9: note: candidate: 'IPAddress::operator u32_t()' (near match)
84 | operator u32_t() { return isV4()? v4(): (u32_t)0; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:84:9: note: no known conversion from 'u32_t' {aka 'long unsigned int'} to 'ip_addr*'
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:162:9: note: candidate: 'IPAddress::operator const ip_addr_t*() const' (near match)
162 | operator const ip_addr_t*() const { return &_ip; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:162:9: note: no known conversion from 'const ip_addr_t*' {aka 'const ip4_addr*'} to 'ip_addr*'
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:163:9: note: candidate: 'IPAddress::operator ip_addr_t*()' (near match)
163 | operator ip_addr_t*() { return &_ip; }
C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\cores\esp8266/IPAddress.h:163:9: note: no known conversion from 'ip_addr_t*' {aka 'ip4_addr*'} to 'ip_addr*'
In file included from C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\UDPRECIEVER_SERVER__Final_With_Internet.ino:6:
C:\Users\Navid.H\Documents\Arduino\UDPRECIEVER_SERVER__Final_With_Internet\dhcpserver.h:117:36: note: initializing argument 1 of 'void dhcps_set_DNS(ip_addr*)'
117 | void dhcps_set_DNS(struct ip_addr *dns_ip) ICACHE_FLASH_ATTR;
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Navid.H\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi
exit status 1
