Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
In file included from C:\Users\Personal\Documents\Arduino\final\final.ino:11:0:
C:\Users\Personal\Documents\Arduino\final\mq2.h: In function 'void setup()':
mq2.h:25:30: error: 'sendUptime' was not declared in this scope
timer.setInterval(1000L, sendUptime);
C:\Users\Personal\Documents\Arduino\final\final.ino: At global scope:
final:13:11: error: redefinition of 'char auth []'
char auth[] = BLYNK_AUTH_TOKEN;
C:\Users\Personal\Documents\Arduino\final\mq2.h:9:6: note: 'char auth [33]' previously defined here
char auth[] = "5iXYo8D2VpHQ0q84BLAF8JRL7YgKLBb6";
final:14:11: error: redefinition of 'char ssid []'
char ssid[] = "Chandra";
C:\Users\Personal\Documents\Arduino\final\mq2.h:14:6: note: 'char ssid [8]' previously defined here
final:15:11: error: redefinition of 'char pass []'
char pass[] = "passw0rd@22";
C:\Users\Personal\Documents\Arduino\final\mq2.h:15:6: note: 'char pass [12]' previously defined here
final:105:12: error: redefinition of 'BlynkTimer timer'
BlynkTimer timer;
C:\Users\Personal\Documents\Arduino\final\mq2.h:5:12: note: 'BlynkTimer timer' previously declared here
BlynkTimer timer;
C:\Users\Personal\Documents\Arduino\final\final.ino: In function 'void setup()':
final:107:6: error: redefinition of 'void setup()'
void setup() //Setup function - only function that is run in deep sleep mode
C:\Users\Personal\Documents\Arduino\final\mq2.h:23:6: note: 'void setup()' previously defined here
C:\Users\Personal\Documents\Arduino\final\final.ino: In function 'void loop()':
final:136:6: error: redefinition of 'void loop()'
void loop() //Loop function
C:\Users\Personal\Documents\Arduino\final\mq2.h:55:6: note: 'void loop()' previously defined here
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\Personal\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\Personal\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
Multiple libraries were found for "WiFi.h"
Used: C:\Users\Personal\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Not used: C:\Users\Personal\Documents\Arduino\libraries\WiFiNINA
exit status 1
option enabled in File -> Preferences.
