#include <Arduino.h>
#include <ArduinoJson.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <HTTPClient.h>
#include <UniversalTelegramBot.h>
#include <Arducam.h>
#include <Adafruit_GPS.h>
#include <IRremote.h>
const char* ssid = "your_wifi_ssid";
const char* password = "your_wifi_password";
#define BOT_TOKEN "your_bot_token"
#define CHAT_ID "your_chat_id"
WiFiClientSecure client;
HTTPClient http;
OV2640 cam;
Adafruit_I2S i2s;
Adafruit_GPS gps(&Serial1);
OV2640() {
// Initialize the camera
#define IR_RECEIVER 18
#define TAKE_PHOTO 0x1FE807F
#define START_AUDIO 0x1FE40BF
#define STOP_AUDIO 0x1FE20DF
#define START_VIDEO 0x1FEC03F
#define STOP_VIDEO 0x1FE20DF
#define GET_LOCATION 0x1FEF807
#define GPS_RXD 16
#define GPS_TXD 17
Serial1.begin(9600);
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
cam.init();
cam.setFrameSize(FRAME_320X240);
cam.setContrast(2);
cam.setBrightness(0);
cam.setSaturation(2);
i2s.begin();
i2s.setGain(0.5);
i2s.setBufferSize(1024);
Serial.println("Setup complete");
if (Serial.available()) {
char c = Serial.read();
if (c == '\n') {
processSerialCommand();
if (Serial1.available()) {
gps.read();
if (gps.newNMEAreceived()) {
if (!gps.parse(gps.lastNMEA())) {
return;
void processSerialCommand() {
String command = Serial.readStringUntil('\n');
command.trim();
if (command.equals("take_photo")) {
takePhoto();
} else if (command.equals("start_audio")) {
startAudioRecording();
} else if (command.equals("stop_audio")) {
stopAudioRecording();
} else if (command.equals("start_video")) {
startVideoRecording();
} else if (command.equals("stop_video")) {
stopVideoRecording();
} else if (command.equals("get_location")) {
sendLocation();
void takePhoto() {
Serial.println("Taking photo...");
cam.startCapture();
uint8_t* buffer = cam.captureFrame();
cam.stopCapture();
File photoFile = SD.open("/photo.jpg", FILE_WRITE);
if (photoFile) {
photoFile.write(buffer, cam.frameSize());
photoFile.close();
sendPhoto("/photo.jpg");
Serial.println("Photo sent successfully");
Serial.println("Failed to open photo file");
void startAudioRecording() {
Serial.println("Starting audio recording...");
i2s.start();
void stopAudioRecording() {
Serial.println("Stopping audio recording...");
i2s.stop();
sendAudio("/audio.wav");
Serial.println("Audio sent successfully");
void startVideoRecording() {
Serial.println("Starting video recording...");
cam.startCapture();
// Code to start recording video with your specific video module
void stopVideoRecording() {
Serial.println("Stopping video recording...");
// Code to stop recording video with your specific video module
cam.stopCapture();
sendVideo("/video.mp4");
Serial.println("Video sent successfully");
void sendLocation() {
Serial.println("Getting GPS location...");
if (gps.fix) {
String latitudeStr = String(gps.latitude, 6);
String longitudeStr = String(gps.longitude, 6);
String url = "https://api.telegram.org/bot" + String(BOT_TOKEN) + "/sendLocation?chat_id=" + String(CHAT_ID) +
"&latitude=" + latitudeStr + "&longitude=" + longitudeStr;
http.begin(client, url);
int httpResponseCode = http.GET();
if (httpResponseCode == 200) {
Serial.println("Location sent successfully");
Serial.print("Failed to send location. Error code: ");
Serial.println(httpResponseCode);
http.end();
Serial.println("Failed to get GPS location");
void sendPhoto(const String& filePath) {
File photoFile = SD.open(filePath, FILE_READ);
if (photoFile) {
WiFiClient client;
if (client.connect("api.telegram.org", 443)) {
String head = "--BOUNDARY123\r\nContent-Disposition: form-data; name=\"chat_id\"\r\n\r\n" + String(CHAT_ID) + "\r\n";
String body = "--BOUNDARY123\r\nContent-Disposition: form-data; name=\"photo\"; filename=\"photo.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
String tail = "\r\n--BOUNDARY123--\r\n";
client.println("POST /bot" + String(BOT_TOKEN) + "/sendPhoto HTTP/1.1");
client.println("Host: api.telegram.org");
client.println("Content-Length: " + String(head.length() + body.length() + photoFile.size() + tail.length()));
client.println("Content-Type: multipart/form-data; boundary=BOUNDARY123");
client.println();
client.print(head);
client.print(body);
uint8_t buffer[1024];
int bytesRead;
while ((bytesRead = photoFile.read(buffer, sizeof(buffer))) > 0) {
client.write(buffer, bytesRead);
photoFile.close();
client.print(tail);
String response = client.readString();
Serial.println(response);
Serial.println("Failed to connect to Telegram server");
if (photoFile) {
WiFiClient client;
client.println();
client.print(head);
client.print(body);
int bytesRead;
photoFile.close();
client.print(tail);
void sendAudio(const String& filePath) {
File audioFile = SD.open(filePath, FILE_READ);
if (audioFile) {
WiFiClient client;
String head = "--BOUNDARY123\r\nContent-Disposition: form-data; name=\"audio\"; filename=\"audio.wav\"\r\nContent-Type: audio/wav\r\n\r\n";
client.println("POST /bot" + String(BOT_TOKEN) + "/sendAudio HTTP/1.1");
client.println("Content-Length: " + String(head.length() + audioFile.size() + tail.length()));
client.println();
client.print(head);
int bytesRead;
while ((bytesRead = audioFile.read(buffer, sizeof(buffer))) > 0) {
audioFile.close();
client.print(tail);
Serial.println("Failed to open audio file");
void sendVideo(const String& filePath) {
File videoFile = SD.open(filePath, FILE_READ);
if (videoFile) {
WiFiClient client;
String head = "--BOUNDARY123\r\nContent-Disposition: form-data; name=\"video\"; filename=\"video.mp4\"\r\nContent-Type: video/mp4\r\n\r\n";
client.println("POST /bot" + String(BOT_TOKEN) + "/sendVideo HTTP/1.1");
client.println("Content-Length: " + String(head.length() + videoFile.size() + tail.length()));
client.println();
client.print(head);
int bytesRead;
while ((bytesRead = videoFile.read(buffer, sizeof(buffer))) > 0) {
videoFile.close();
client.print(tail);
Serial.println("Failed to open video file");
if (gps.fix) {
http.end();
This message appears to me
/storage/emulated/0/ArduinoDroid/userlibraries/ArduCAM/src/Arducam.h:411:21: error: expected unqualified-id before numeric constant
What should I do in this case, knowing that I use Arduino Droid
