Error while compliling
Hi there I'm pretty new to Arduino, and overall everything worked but now I keep getting this:
  enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Uno"
sketch_jun28a:110: error: expected unqualified-id before '{' token
Thats my code
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
#include <Servo.h>
Servo myservo;
const int
PWM_A   = 3,
DIR_A   = 12,
BRAKE_A = 9,
SNS_A   = A0;
boolean isRed;
boolean isOK;
boolean redWanted;
boolean whiteWanted;
int pos = 0;
int led = 12;
int digitalPin1 = 10;
int digitalPin2 = 11;
int analogPin3 = A3;
int analogPin4 = A4;
int test = 0;
// the setup routine runs once when you press reset:
  // Configure the A output
  pinMode(BRAKE_A, OUTPUT);  // Brake pin on channel A
  pinMode(DIR_A, OUTPUT);    // Direction pin on channel A
  pinMode(digitalPin1, INPUT);
  pinMode(digitalPin2, INPUT);
  pinMode(analogPin3, INPUT);
  // Open Serial communication
  // initialize the digital pin as an output.
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  Serial.begin(9600);          //  setup serial
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, LOW);   // turn the LED on (HIGH is the voltage level)
  delay(100);               // wait for a second
  analogWrite(PWM_A, 45);     // Set the speed of the motor
  //while(1);
	//Value on pin 1: 1 ==> bear is red
	//				  0 ==> bear is not red
	//Value on pin 2: 1 ==> bear is ok
	//				  0 ==> bear is not ok
	isRed = false;
	isOK = false;
	redWanted = false;
	whiteWanted = false;
	if (digitalRead(digitalPin1) == HIGH)
  isRed = true;
  Serial.println("Is Red");
  isRed = false;
  Serial.println("Is not Red");
	if (digitalRead(digitalPin2) == LOW)
  isOK = true;
  Serial.println("Is ok");
  isOK = false;
  Serial.println("Is not ok");
	if (analogRead(analogPin3) > 800)
  redWanted = true;
  Serial.println("Red is Wanted");
  redWanted = false;
  whiteWanted = true;
  delay(2000);
  redWanted = true;
if (analogRead(analogPin3) < 800)
whiteWanted = true;
redWanted = false;
	//if (isRed = true;
    if(isRed == true && redWanted == true && isOK == true)
        digitalWrite(led, HIGH);    // turn the LED off by making the voltage LOW
for(pos = 0; pos>=180; pos-=1);  // goes from 0 degrees to 180 degrees
	{                                  // in steps of 1 degree
		myservo.write(pos);              // tell servo to go to position in variable 'pos'
		delay(20);
Serial.println("fahre aus");
// waits 20ms for the servo to reach the position
for(pos = 0; pos>=180; pos-=1);     // goes from 180 degrees to 0 degrees
	delay(20);                       // waits 20ms for the servo to reach the position
Serial.println("fahre ein");
       // test = digitalRead(digitalPin1);  // Input auslesen
//if (test == HIGH) {            // Wenn Input= HIGH
//digitalWrite(led, LOW);  // dann LED aus
//else {
//digitalWrite(led, HIGH); // andernfalls LED an.
 // Serial.println(isRed);
I'm happy for any help
Thanks a lot
Mena
Look in the line 110 area.
Also does this look correct ;)?
for(pos = 0; pos>=180; pos-=1) ;
Usually, putting a semicolon at the end of a for loop is really not what you want to do.
  for (pos = 0; pos >= 180; pos -= 1); // goes from 0 degrees to 180 degrees
and that's been done in several places. Also, it seems that you have your braces mismatched.
So much for trying to teach.
Thanks for the help, I already removed the { and the ;
I've set this because otherwise I keep getting more and more errors:
It don't understands the Sweep task anymore (Copied from here: https://www.arduino.cc/en/Tutorial/Sweep)
So I thought I might be on the right way.
sketch_jun28a:110: error: expected unqualified-id before 'for'
sketch_jun28a:110: error: expected constructor, destructor, or type conversion before '>=' token
sketch_jun28a:110: error: expected constructor, destructor, or type conversion before '-=' token
Thanks a lot
Mena
Fix this too:
const int
PWM_A = 3,
DIR_A = 12,
BRAKE_A = 9,
SNS_A = A0;
Perhaps:
const int PWM_A = 3;
const int DIR_A = 12;
const int BRAKE_A = 9;
const int SNS_A = A0;
To save memory, all could be byte instead of int also (value between 0 and 255, yes?)
Syntactically, there's nothing wrong with:
const int
PWM_A   = 3,
DIR_A   = 12,
BRAKE_A = 9,
SNS_A   = A0;
It will compile just fine. However, what CrossRoads shows is a better form of coding the definitions.
@LarryD: Sorry 'bout that.
The initial error is probably from this:
if(isRed == true && redWanted == true && isOK == true) <<<< missing a { here
} <<<< to go with this one
LarryD:
LarryD:
I guess your perception of teaching and mine are different.
You did not teach , you just pointed out what the compiler already done.
I would call it nagging, but what do I know.
To the OP
read - up on for() command definition / format .
Initial (expression), test (expression), increment (expression) and statement - the body of the command.
The "increment" can be negative, weird but mathematically acceptable.
If you use IDE "autoFormat" tool, you can see where the extra ; should NOT be easier.
If you use "line numbers " in you post text people can find the line where the compiler got stuck easier.
And if you carefully MATCH your comments with desired action - you can see where your expressions (initial and test expressions) are codded wrong too.
for ( init-expr; test-expr; increment-expr) { statement }
Addendum
After reading Crossroads post - check your brackets pairs ( {}) ) , on "broken 1.6.5. " you can still position you mouse on starting bracket and the corresponding end bracket one should get /display a blue frame around it. This feature used to highlight the entire code block inside the brackets.
PS the composite AND statement is correct! The brackets are not.
What, indeed, do you know, Vaclav?
The compiler did not and could not point out a semicolon at the end of a "for".
(it's only necessary to quote someone once. Don't worry, you'll get the hang of it sooner or later.)
You know what the compiler was saying but did the OP.
That's why I brought it to their attention line 110 may be an area of interest.
They may have missed this. (And they did as they could not find their error)
Also I gave a hint that the "for" function may be in question.
Deferent ways of trying to help I guess.
