Error while detecting libraries included by
Hello everybody, Sorry if the topic has already existed.
I am trying to port my own project to M5stack core2 by using Arduino IDE(ver 1.8.13) on Win10.
but there are so many errors just like
”Error while detecting libraries included by ...” while compiling.
directory tree:
SketchBook
-------|----myProject
-----------------|----myProject.ino //dummy file
-----------------|----src
------------------------|----myOwnProject //source code
I have been searching on google, but haven't found a clear solution yet.
Is there any solution to solve this problem?
my own project has its own Makefile created for building,
so I prefer to know that is there a way to make Arduino IDE calling my own Makefile?
Thanks,
Best regards
Hello @clouds-hyhy. Please post your sketch.
Arduino Team
Thanks for replying me.
→Sorry, I am a beginner of Arduino IDE, you mean the whole detail of this porting project?
total directory tree:
SketchBook
-------|----libraries
-------------|----M5Core2 //head file for M5stack Core2
-----------------|----myProject.ino //dummy file(default, no modifying)
------------------------|----myOwnProject //(source code + makefile)
Because of confidential information, I am afraid that
I can not show(upload) the detail of myOwnProject directory.
except myOwnProject directory, the rest of files are all default, no modifying.
build error is just like:↓
"Error while detecting libraries included by C:\Users[user_name]\AppData\Local\Temp\arduino_build_89825\sketch\src\myOwnProject [directory _name]......[directory_name]\xxxx.cpp"
OK, then provide a minimal demonstration of the issue. That is even better.
Sorry, it's a little difficult for me to make a minimal demonstration.
I am trying to upload the detail information of compiling error.
but because of "New user", I can not upload file(.zip).
I don't know whether it's useful, I uploaded a capture image of error information.
“Error while detecting libraries included by .....\xxx.cpp" means
the #include(relative path) in my xxx.cpp is not correct?
Could you tell me what are the potential reasons would cause this problem?
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. When you encounter an error, you'll see a button on the right side of the orange bar "Copy error messages" in the Arduino IDE (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  2. In a forum reply here, click on the reply field.
  3. Press Ctrl + v. This will paste the error into the reply window.
  4. Select the error output in the editor field.
  5. From the toolbar at the top of the editor field, click the </> button
    codetags2.
  6. Move the cursor outside of the code tags before you add any additional text to your reply.
Thanks for your procedure and I uploaded some error messages.
Arduino:1.8.13 (Windows 10), ボード:"M5Stack-Core2, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 240MHz (WiFi/BT), 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\chenj\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\chenj\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino\SketchBook\libraries -fqbn=m5stack:esp32:m5stack-core2:PSRAM=enabled,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600,DebugLevel=none -ide-version=10813 -build-path C:\Users\chenj\AppData\Local\Temp\arduino_build_392758 -warnings=none -build-cache C:\Users\chenj\AppData\Local\Temp\arduino_cache_487897 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\mkspiffs\0.2.3 -verbose D:\Arduino\SketchBook\myProject\myProject.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\chenj\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\chenj\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino\SketchBook\libraries -fqbn=m5stack:esp32:m5stack-core2:PSRAM=enabled,PartitionScheme=default,CPUFreq=240,UploadSpeed=921600,DebugLevel=none -ide-version=10813 -build-path C:\Users\chenj\AppData\Local\Temp\arduino_build_392758 -warnings=none -build-cache C:\Users\chenj\AppData\Local\Temp\arduino_cache_487897 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\tools\mkspiffs\0.2.3 -verbose D:\Arduino\SketchBook\myProject\myProject.ino
Using board 'm5stack-core2' from platform in folder: C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\1.0.7
Using core 'esp32' from platform in folder: C:\Users\chenj\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\1.0.7
Detecting libraries used...
"C:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/config" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_trace" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_update" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/asio" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bootloader_support" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/coap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/console" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/driver" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-tls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_event" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_client" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_server" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_https_ota" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ethernet" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/expat" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fatfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freemodbus" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freertos" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/heap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/idf_test" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/jsmn" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/json" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/libsodium" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/log" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/lwip" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mbedtls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mdns" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/micro-ecc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mqtt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/newlib" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nghttp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nvs_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/openssl" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protobuf-c" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protocomm" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/pthread" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/sdmmc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/soc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spi_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spiffs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcp_transport" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ulp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/vfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wear_levelling" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32-camera" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5STACK_Core2 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5STACK_Core2\"" "-DARDUINO_VARIANT=\"m5stack_core2\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\cores\\esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\variants\\m5stack_core2" "C:\\Users\\chenj\\AppData\\Local\\Temp\\arduino_build_392758\\sketch\\myProject.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/config" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_trace" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_update" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/asio" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bootloader_support" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/coap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/console" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/driver" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-tls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_event" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_client" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_server" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_https_ota" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ethernet" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/expat" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fatfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freemodbus" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freertos" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/heap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/idf_test" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/jsmn" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/json" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/libsodium" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/log" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/lwip" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mbedtls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mdns" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/micro-ecc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mqtt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/newlib" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nghttp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nvs_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/openssl" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protobuf-c" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protocomm" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/pthread" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/sdmmc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/soc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spi_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spiffs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcp_transport" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ulp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/vfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wear_levelling" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32-camera" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5STACK_Core2 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5STACK_Core2\"" "-DARDUINO_VARIANT=\"m5stack_core2\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\cores\\esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\variants\\m5stack_core2" "C:\\Users\\chenj\\AppData\\Local\\Temp\\arduino_build_392758\\sketch\\src\\myOwnProject\\Contents\\Bitmap\\BMP_CK\\SRC\\BMP_CK.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Error while detecting libraries included by C:\Users\chenj\AppData\Local\Temp\arduino_build_392758\sketch\src\myOwnProject\Contents\Bitmap\BMP_CK\SRC\BMP_CK.cpp
"C:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/config" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_trace" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/app_update" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/asio" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bootloader_support" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/bt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/coap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/console" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/driver" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-tls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_event" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_client" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_http_server" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_https_ota" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ethernet" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/expat" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fatfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freemodbus" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/freertos" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/heap" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/idf_test" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/jsmn" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/json" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/libsodium" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/log" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/lwip" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mbedtls" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mdns" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/micro-ecc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/mqtt" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/newlib" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nghttp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/nvs_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/openssl" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protobuf-c" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/protocomm" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/pthread" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/sdmmc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/soc" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spi_flash" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/spiffs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcp_transport" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/ulp" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/vfs" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wear_levelling" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp32-camera" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/esp-face" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_M5STACK_Core2 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5STACK_Core2\"" "-DARDUINO_VARIANT=\"m5stack_core2\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\cores\\esp32" "-IC:\\Users\\chenj\\AppData\\Local\\Arduino15\\packages\\m5stack\\hardware\\esp32\\1.0.7\\variants\\m5stack_core2" "C:\\Users\\chenj\\AppData\\Local\\Temp\\arduino_build_392758\\sketch\\src\\myOwnProject\\Contents\\Bitmap\\BitmapCheck\\SRC\\BitmapCheck.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Error while detecting libraries included by C:\Users\chenj\AppData\Local\Temp\arduino_build_392758\sketch\src\myOwnProject\Contents\Bitmap\BitmapCheck\SRC\BitmapCheck.cpp
compilation terminated.
exit status 1
