Error while trying to use scheduler.startLoop in scheduler library ardiuno DUE
Hi there guys!
I am new to using the ardiuno due. (just got it in today) I am actually having a bit of trouble trying to compile the code. I changed the Wprogram.h to Arduino.h and the example sketch compiles fine. The problem starts when I try to compile the sketch using Scheduler.startLoop.
The error that pops up is: expected unqualified-id before '.' token. and it highlights Scheduler.startLoop
{I am trying to run two loops simultaneously where one displays the pressure sensor value from a load cell and the other displays a desired value (input from the serial monitor). }
I would really appreciate it if some one could help me out with what is it exactly that I am doing wrong! The code is as follows.
#include <Scheduler.h>
//variables for actual_value
const int digitPins1[4] = {
4, 5, 6
}; //4 common anode pins of the actual_value
const int clockPin1 = 11; //74HC595 Pin 11
const int latchPin1 = 12; //74HC595 Pin 12
const int dataPin1 = 13; //74HC595 Pin 14
const int pressurePin = A0; //pressure sensor pin
const byte digit1[10] = //actual seven segment digits in bits
B00111111, //0
B00000110, //1
B01011011, //2
B01001111, //3
B01100110, //4
B01101101, //5
B01111101, //6
B00000111, //7
B01111111, //8
B01101111 //9
int digitBuffer1[3] = {
0
int digitScan1 = 0;
float pressureValue;
//variables for desired_display
const int digitPins2[3] = {
A1, A2, A3
}; //4 common anode pins of the desired_display
const int clockPin2 = 11; //74HC595-2 Pin 11
const int latchPin2 = 12; //74HC595-2 Pin 12
const int dataPin2 = 13; //74HC595-2 Pin 14
const byte digit2[10] = //desired seven segment digits in bits
B00111111, //0
B00000110, //1
B01011011, //2
B01001111, //3
B01100110, //4
B01101101, //5
B01111101, //6
B00000111, //7
B01111111, //8
B01101111 //9
int digitBuffer2[3] = {
0
int digitScan2 = 0;
unsigned int desiredValue = 0; //desiredValue input from the computer using se
char incomingByte;
Scheduler.startLoop(loop1);
//setup for actual_display
for (int i = 0; i < 3; i++)
pinMode(digitPins1*, OUTPUT);*
  • pinMode(pressurePin, INPUT);*
  • pinMode(latchPin1, OUTPUT);*
  • pinMode(clockPin1, OUTPUT);*
  • pinMode(dataPin1, OUTPUT);*
  • //setup for desired_display*
  • for (int i = 0; i < 3; i++)*
    _ pinMode(digitPins2*, OUTPUT);_
    _
    }_
    _
    pinMode(latchPin2, OUTPUT);_
    _
    pinMode(clockPin2, OUTPUT);_
    _
    pinMode(dataPin2, OUTPUT);_
    _
    }_
    //writes the actual_pressure value on display*
    void updateDispActual() {
    * for (byte j = 0; j < 3; j++)*
    * digitalWrite(digitPins1[j], LOW);*
    * digitalWrite(latchPin1, LOW);*
    * shiftOut(dataPin1, clockPin1, MSBFIRST, B11111111);*
    * digitalWrite(latchPin1, HIGH);*
    * delayMicroseconds(100);*
    * digitalWrite(digitPins1[digitScan1], HIGH);*
    * shiftOut(dataPin1, clockPin1, MSBFIRST, ~digit1[digitBuffer1[digitScan1]]);*
    * digitScan1++;*
    * if (digitScan1 > 2) digitScan1 = 0;*
    //wrties desired_pressure value to display
    void updateDispDesired() {
    * digitalWrite(digitPins2[j], LOW);*
    * digitalWrite(latchPin2, LOW);*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, B11111111);*
    * digitalWrite(latchPin2, HIGH);*
    * digitalWrite(digitPins2[digitScan2], HIGH);*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, ~digit2[digitBuffer2[digitScan2]]);*
    * digitScan2++;*
    * if (digitScan2 > 2) digitScan2 = 0;*
    * //converts digital value read by adc to kg*
    _ pressureValue = (((analogRead(pressurePin) / 1023.0) * 5.0) / 0.0099);
    * //pressure value display*
    * pressureValue = int(pressureValue);*
    * digitBuffer1[2] = int(pressureValue) / 1000;*
    * digitBuffer1[1] = (int(pressureValue) % 100) / 10;*
    * digitBuffer1[0] = (int(pressureValue) % 10);*
    * updateDispActual();*
    * delay(2);*
    void loop1() {
    * if (Serial.available() > 0) { // something came across serial*
    * desiredValue = 0; // throw away previous integerValue*
    * while (1) { // force into a loop until 'n' is received*
    * incomingByte = Serial.read();*
    * if (incomingByte == '\n') break; // exit the while(1), we're done receiving*
    * if (incomingByte == -1) continue; // if no characters are in the buffer read() returns -1*
    desiredValue = 10; // shift left 1 decimal place_
    _
    // convert ASCII to integer, add, and shift left 1 decimal place*_
    * desiredValue = int(((incomingByte - 48) + desiredValue));*
    * if (desiredValue > 420)*
    * desiredValue = 420;*
    * Serial.println(desiredValue);*
    * digitBuffer2[2] = int(desiredValue) / 100;*
    * digitBuffer2[1] = (int(desiredValue) % 100) / 10;*
    * digitBuffer2[0] = (int(desiredValue) % 10);*
    * updateDispDesired();*
    * delay(2);*
    * yield();*
Hello alibaba9292,
Wprogram.h? I am not sure but it seems to me that you are using the Arduino Schedule library for AVR.
http://playground.arduino.cc/Code/Scheduler
This library is not intended for Arduino DUE (SAM based).
The IDE 1.5.x has its own scheduler library. Why not try the MultipleBlinks example as a start point?.
File->Examples->Scheduler
Regards, Palliser
@Palliser
THANK YOU!!!!!!!!!!!!!!!!!!!!!!! I am so stupid that is exactly what I was doing :smiley:
cant thank you enough for your help :smiley:
I think now should be able to ace my final year project! everything was working well individually. What I couldnt find was was a way to concurrently do all my 3 functions; display desired pressure value, display current pressure value and the third being a control loop to to reach desired value.
