Error while uploading data on firebase using esp32
Hi everyone,
I'm working on a project where I have multiple sensors connected to an Arduino Uno. The sensors I'm using are MQ5, MQ7, MQ135 (for gas detection), DHT11 (for temperature and humidity), and GP2Y1010AU0F (for dust density). The Arduino reads the sensor data and then sends this data to an ESP32. The ESP32 is supposed to upload the data to Firebase using the Firebase_ESP_Client library.
However, I'm encountering an issue where the ESP32 throws an error about the data format being incorrect when trying to upload to Firebase.
code for arduino uno
  Serial.begin(9600); // Initialize Serial communication at 9600 baud rate
  // Read sensor values
  float mq5Value = analogRead(A0); // Read MQ5 sensor value from analog pin A0
  float mq7Value = analogRead(A1); // Read MQ7 sensor value from analog pin A1
  // Format data as a CSV string
  String data = String(mq5Value) + "," + String(mq7Value);
  // Send data to ESP32
  Serial.println(data);
  delay(2000); // Wait for 2 seconds before sending the next data
code for esp32
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
// Provide the token generation process info.
#include <addons/TokenHelper.h>
// Provide the RTDB payload printing info and other helper functions.
#include <addons/RTDBHelper.h>
// Replace these with your WiFi credentials
#define WIFI_SSID "your_wifi_ssid"
#define WIFI_PASSWORD "your_wifi_password"
// Replace these with your Firebase project credentials
#define DATABASE_URL "your_database_url"
#define API_KEY "your_api_key"
// Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
bool signupOK = false;
// Use HardwareSerial for communication with Arduino Uno
HardwareSerial mySerial(2); // Use UART2 (TX2: GPIO17, RX2: GPIO16)
  Serial.begin(115200); // Initialize Serial Monitor for debugging
  mySerial.begin(9600, SERIAL_8N1, 16, 17); // Initialize UART2 at 9600 baud rate, TX2: GPIO17, RX2: GPIO16
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
    Serial.print(".");
  Serial.print("Connected with IP: ");
  // Assign the API key (required)
  config.api_key = API_KEY;
  // Assign the RTDB URL (required)
  config.database_url = DATABASE_URL;
  // Sign up
  if (Firebase.signUp(&config, &auth, "", "")) {
    Serial.println("ok");
    signupOK = true;
    Serial.printf("%s\n", config.signer.signupError.message.c_str());
  // Assign the callback function for the long running token generation task
  config.token_status_callback = tokenStatusCallback; // See addons/TokenHelper.h
  Firebase.begin(&config, &auth);
  Firebase.reconnectWiFi(true);
  if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 5000 || sendDataPrevMillis == 0)) {
    sendDataPrevMillis = millis();
    if (mySerial.available()) {
      String data = mySerial.readStringUntil('\n'); // Read data from Arduino Uno
      Serial.print("Received data from Arduino Uno: ");
      // Parse the received data
      float mq5Value, mq7Value;
      if (sscanf(data.c_str(), "%f,%f", &mq5Value, &mq7Value) == 2) {
        Serial.print("Parsed MQ5 Value: ");
        Serial.println(mq5Value);
        Serial.print("Parsed MQ7 Value: ");
        Serial.println(mq7Value);
        FirebaseJson json;
        json.set("MQ5", mq5Value);
        json.set("MQ7", mq7Value);
        if (Firebase.RTDB.setJSON(&fbdo, "/sensorData", &json)) {
          Serial.println("Data sent to Firebase successfully");
          Serial.println("Failed to send data to Firebase");
          Serial.println("REASON: " + fbdo.errorReason());
        Serial.println("Error: Received string format is incorrect");
I think that for anybody to be able to advise you will need to provide at least the ESP32 code and preferably the Uno code. Please don't forget to use code tags when posting code as described in How to get the best out of this forum.
Post the error (again using code tags).
Note:
I have no experience with Firebase; also not with ESP32.
Hi @5herazahmed_100
I have faced some issues when I used too many sensors to one arduino, you can try dividing the sensors, half to the Arduino Uno and the other half to the ESP32, if the format is incorrect, you can check if the baud rate between the UNO and the ESP is same.
Also check the individual communication protocol of the sensors.
I suggest, try with one sensor at a time till you connect all the sensors.
Exactly! when i connect just one sensor it works great.
