Error while uploading program
Pls help...
I did not have a programmer and i had a new atmega328p micro controller so i decided to follow this tutorial :
and use the on board 16u2 as a programmer , everything went fine and i flashed my boot loader on atmega328p , then I re-flashed 16u2 with :
Arduino-usbserial-atmega16u2-Uno-Rev3.hex
which changes my uno R3 board back from and avrisp mkii to being an uno , but now it is being recognized as uno R3 but whenever i upload a program it shows :
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x87
(NOTE)^^this code is different every time
and I found another tutorial in which it says this :
"Note: Initially 16U2 will run in the Atmel Studio mode, if you would like to change it, Fit and Unfit a
Link on ICSP1 between pins 5-6 (this will reset the 16U2 and it will change the mode, you will see the LEDs blinking 4-5 times). If you are using Arduino Uno R3, you will need to pull HWB pin to +5V before you use the Reset Link, otherwise your 16U2 will go into DFU mode and will not toggle between Atmel Studio and Avrdude mode."
so i think my board is stuck in Atmel studio mode and i need to switch it to Avrdude mode but i cant understand how to do this , any help will be greatly appreciated :sob:
Link to other tutorial :
http://www.28pins.com/learning/how-to-program-atmega16u2-to-become-avrisp-mkii/
Btw where is the HWB pin on the arduino and how would i go about pulling it to +5V.
(Arduino is recognized in computer.)
To tell if your 16u2 is back to normal operation, do the loop back test which is described in one of the pinned posts at the top of this forum.
just did the loop back test works as it is said to, every thing I enter in the Serial monitor gets printed.
Ok, so you don't need to worry about the 16u2. I don't think that tutorial results in a properly burned bootloader (including proper fuse settings) on the ATmega328P. I recommend getting an ISP programmer such as USBasp with a 6-pin connector, or use another Arduino as an ISP programmer.
Or if you really want to get into intricate detail, study fuse settings by looking in the ATmega328P datasheet and reading online, see in the Arduino IDE built in boards.txt file what the fuse settings should be for an Uno, and investigate how to set those in Atmel Studio while you are repeating the tutorial steps. It could be that tutorial will work with a few more details added.
can u tell me what this is :
and where the HWB pin is located pls
I don't know enough about what he's talking about there, but I'm also fairly confident you don't need to worry about that section since you indicated success in writing the bootloader when you did the ISP programming with Atmel Studio, and also successful restore the 16u2 to normal as proven by the loop back test.
so the problem is with the 328p not being flashed properly, and not with the board?
This is very a important note:
" i had a new atmega328p micro controller"
As mentioned by dmjlambert, you need to set atmega328p fuses. Have a look here: Standard Fuse Settings for 16Mhz ATMega328p - Microcontrollers - Arduino Forum
PS - If you just want the same ones as used in a standard Arduino, you can find them in the boards.txt file:
uno.bootloader.low_fuses=0xff
uno.bootloader.high_fuses=0xde
uno.bootloader.extended_fuses=0x05
Use AVR studio -> Fuses to set the Fuses. That should fix your problem. Please, let me know if it helped.
I believe, that the Arduino-usbserial-atmega16u2-Uno-Rev3.hex is the correct firmware.
This is about completelly different firmware and it doesnt apply to your situation:
OMG that did the trick now it works fine!!!!
cannot thank you two enough for your quick replies and splendid help :slight_smile: , Just shows how amazing the
Arduino community is ..... Thank you very much.
Great! If you can post the steps you did to supplement that tutorial, it would benefit future readers of this thread.
I will, but i am kind of new to the Arduino forums so... should i make a new thread or just post all the steps i followed as a reply?
You can describe it here. I will update the blog. I probably only need to add the Fuse programming for new ATMega328P chip.
yes that is one of the major additional step i took and it was basically done as you mentioned it earlier, and the one other thing i did (and i think this is only required for windows 8/8.1 and 10), is that i used libusb-win32 driver for AVRISP instead of the jungo drivers it automatically installs, this step is very important as without it Atmel Studio cannot connect to the AVRISP, these are the steps i followed to change the drivers:
  • Download Zadig: http://zadig.akeo.ie/. Zadig is a USB driver manager for Windows, and saved me a hundred times this year. The last version comes with the libusb-win32 (v1.2.6.0) driver embedded.
  • Open Zadig, Options, List All Devices. The AVRISP mkII device should appear in the list.
  • Replace its current driver by libusb-win32 (v1.2.6.0)
That's it! No restart required :slight_smile:
This ^ fix has been referenced from:
third reply from the top.
Thank you.
