Hi All,
I am using Arduino Nano RP 2040 connect and while uploading sketch getting below error.
I am using Arduino IDE 1.8.19 version with Arduino Mbed os nano version 3.4.1.
After enabling verbose logging , have observed below logs
"C:\Users\LENOVO\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.6/elf2uf2" "C:\Users\LENOVO\AppData\Local\Temp\arduino_build_316809/sketch_nov21a.ino.elf" "C:\Users\LENOVO\AppData\Local\Temp\arduino_build_316809/sketch_nov21a.ino.uf2"
"C:\Users\LENOVO\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-size" -A "C:\Users\LENOVO\AppData\Local\Temp\arduino_build_316809/sketch_nov21a.ino.elf"
Sketch uses 91004 bytes (0%) of program storage space. Maximum is 16777216 bytes.
Global variables use 43492 bytes (16%) of dynamic memory, leaving 226844 bytes for local variables. Maximum is 270336 bytes.
Forcing reset using 1200bps open/close on port COM3
C:\Users\LENOVO\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.6/rp2040load -v -D C:\Users\LENOVO\AppData\Local\Temp\arduino_build_316809/sketch_nov21a.ino.elf
rp2040load 1.0.6 - compiled with go1.16.2
An error occurred while uploading the sketch
Any help is appreciated
