Error while uploading the code to esp32
Arduino: 1.8.13 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
In file included from C:\Users\Roston Mascarenhas\Desktop\rtnp1\rtnp1.ino:1:0:
C:\Users\Roston Mascarenhas\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:64:24: error: conflicting declaration 'typedef int8_t prog_int8_t'
     typedef int8_t prog_int8_t;
In file included from C:\Users\Roston Mascarenhas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3-rc3\cores\esp32/WString.h:29:0,
             from C:\Users\Roston Mascarenhas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3-rc3\cores\esp32/Arduino.h:146,
             from sketch\rtnp1.ino.cpp:1:
C:\Users\Roston Mascarenhas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3-rc3\cores\esp32/pgmspace.h:25:14: note: previous declaration as 'typedef char prog_int8_t'
typedef char prog_int8_t;
C:\Users\Roston Mascarenhas\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:68:25: error: conflicting declaration 'typedef int32_t prog_int32_t'
     typedef int32_t prog_int32_t;
C:\Users\Roston Mascarenhas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3-rc3\cores\esp32/pgmspace.h:29:14: note: previous declaration as 'typedef long int prog_int32_t'
typedef long prog_int32_t;
C:\Users\Roston Mascarenhas\Documents\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:69:26: error: conflicting declaration 'typedef uint32_t prog_uint32_t'
     typedef uint32_t prog_uint32_t;
C:\Users\Roston Mascarenhas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.3-rc3\cores\esp32/pgmspace.h:30:23: note: previous declaration as 'typedef long unsigned int prog_uint32_t'
typedef unsigned long prog_uint32_t;
exit status 1
Error compiling for board ESP32 Dev Module.
option enabled in File -> Preferences.
Which libraries should I include to avoid this error
Code which I used
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
mpuInterrupt = true;
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
mpu.initialize();
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(220);
mpu.setYGyroOffset(76);
mpu.setZGyroOffset(-85);
mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
if (devStatus == 0)
// turn on the DMP, now that it's ready
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize);
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024)
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
else if (mpuIntStatus & 0x02)
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
Serial.print("Yaw: ");
Serial.println(ypr[0] * 180/M_PI);
Serial.print("Pitch: ");
Serial.println(ypr[1] * 180/M_PI);
Serial.print("Roll: ");
Serial.println(ypr[2] * 180/M_PI);
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
