error while uploading
sir i am new to arduino so im bit confused i have a g code which i made from inskype please help me in this.
at java.lang.Thread.run(Thread.java:745)
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Arduino: 1.6.3 (Windows 8.1), Board: "Arduino Uno"
java.lang.RuntimeException: Missing the / from the end of a / comment */
at processing.app.preproc.PdePreprocessor.scrubComments(PdePreprocessor.java:411)
at processing.app.preproc.PdePreprocessor.writePrefix(PdePreprocessor.java:89)
at processing.app.debug.Compiler.preprocess(Compiler.java:1160)
at processing.app.debug.Compiler.preprocess(Compiler.java:1134)
at processing.app.debug.Compiler.compile(Compiler.java:356)
at processing.app.debug.Compiler.build(Compiler.java:118)
at processing.app.Sketch.build(Sketch.java:1170)
at processing.app.Sketch.build(Sketch.java:1143)
at processing.app.Editor$BuildHandler.run(Editor.java:2016)
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences. :confused: :confused:
So it's not an upload error, it's a compilation error. It's pretty self explanatory:
Missing the */ from the end of a /* comment */
So you just need to look at your code and add the missing */.
how should i add this
where should i add this code :confused:
You want us to tell you where to put it without us being able to see the code? Good luck. Please read the "how to use this forum" stickies to see how to format and post code and error messages.
can someone give clarity to my pproblem please
The characters /* open (mark the start of) a multi line comment. The / characters close (mark the end) of a multi line comment. A / without a */ just makes the whole code a multi line comment. Comments do not execute.
Post your code and we can help fix it. Don't post your code and you are on your own.
(Scribbled version of C: \Users\vishal\AppData\Local\Temp\ink_ext_XXXXXX.svgEU3GAZ @ 3500.00) /* ( unicorn.py --tab="plotter_setup" --pen-up-angle=50 --pen-down-angle=30 --start-delay=150 --stop-delay=150 --xy-feedrate=3500 --z-feedrate=150 --z-height=0 --finished-height=0 --register-pen=true --x-home=0 --y-home=0 --num-copies=1 --continuous=false --pause-on-layer-change=false C:\Users\vishal\AppData\Local\Temp\ink_ext_XXXXXX.svgEU3GAZ ) G21 (metric ftw) G90 (absolute mode) G92 X0.00 Y0.00 Z0.00 (you are here)
M300 S30 (pen down) G4 P150 (wait 150ms) M300 S50 (pen up) G4 P150 (wait 150ms) M18 (disengage drives) M01 (Was registration test successful?) M17 (engage drives if YES, and continue)
(Polyline consisting of 1 segments.) G1 X-15.55 Y22.88 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-18.19 Y29.03 F3500.00 G1 X-16.95 Y29.03 F3500.00 G1 X-15.46 Y25.34 F3500.00 G1 X-15.02 Y24.10 F3500.00 G1 X-14.58 Y25.28 F3500.00 G1 X-13.04 Y29.03 F3500.00 G1 X-11.84 Y29.03 F3500.00 G1 X-14.46 Y22.88 F3500.00 G1 X-15.55 Y22.88 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X-10.79 Y30.17 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-10.79 Y31.37 F3500.00 G1 X-9.62 Y31.37 F3500.00 G1 X-9.62 Y30.17 F3500.00 G1 X-10.79 Y30.17 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X-10.79 Y22.88 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-10.79 Y29.03 F3500.00 G1 X-9.62 Y29.03 F3500.00 G1 X-9.62 Y22.88 F3500.00 G1 X-10.79 Y22.88 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X-8.29 Y24.71 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-7.13 Y24.88 F3500.00 G1 X-6.59 Y23.93 F3500.00 G1 X-5.34 Y23.59 F3500.00 G1 X-4.14 Y23.89 F3500.00 G1 X-3.74 Y24.57 F3500.00 G1 X-4.09 Y25.13 F3500.00 G1 X-5.29 Y25.48 F3500.00 G1 X-7.08 Y25.98 F3500.00 G1 X-7.84 Y26.57 F3500.00 G1 X-8.10 Y27.40 F3500.00 G1 X-7.88 Y28.16 F3500.00 G1 X-7.31 Y28.74 F3500.00 G1 X-6.56 Y29.04 F3500.00 G1 X-5.55 Y29.17 F3500.00 G1 X-4.11 Y28.96 F3500.00 G1 X-3.20 Y28.39 F3500.00 G1 X-2.80 Y27.44 F3500.00 G1 X-3.95 Y27.30 F3500.00 G1 X-4.40 Y28.04 F3500.00 G1 X-5.46 Y28.31 F3500.00 G1 X-6.62 Y28.07 F3500.00 G1 X-6.96 Y27.52 F3500.00 G1 X-6.82 Y27.15 F3500.00 G1 X-6.37 Y26.87 F3500.00 G1 X-5.33 Y26.61 F3500.00 G1 X-3.59 Y26.12 F3500.00 G1 X-2.82 Y25.58 F3500.00 G1 X-2.54 Y24.68 F3500.00 G1 X-2.88 Y23.70 F3500.00 G1 X-3.87 Y22.99 F3500.00 G1 X-5.33 Y22.74 F3500.00 G1 X-6.52 Y22.86 F3500.00 G1 X-7.39 Y23.24 F3500.00 G1 X-7.97 Y23.85 F3500.00 G1 X-8.29 Y24.71 F3500.00 G1 X-8.29 Y24.71 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X-1.14 Y22.88 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-1.14 Y31.37 F3500.00 G1 X0.03 Y31.37 F3500.00 G1 X0.03 Y28.32 F3500.00 G1 X0.96 Y28.96 F3500.00 G1 X2.11 Y29.17 F3500.00 G1 X3.45 Y28.90 F3500.00 G1 X4.26 Y28.15 F3500.00 G1 X4.50 Y26.78 F3500.00 G1 X4.50 Y22.88 F3500.00 G1 X3.33 Y22.88 F3500.00 G1 X3.33 Y26.78 F3500.00 G1 X2.95 Y27.91 F3500.00 G1 X1.87 Y28.27 F3500.00 G1 X0.88 Y28.03 F3500.00 G1 X0.23 Y27.38 F3500.00 G1 X0.03 Y26.24 F3500.00 G1 X0.03 Y22.88 F3500.00 G1 X-1.14 Y22.88 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X10.82 Y23.64 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X9.56 Y22.94 F3500.00 G1 X8.27 Y22.74 F3500.00 G1 X7.26 Y22.86 F3500.00 G1 X6.51 Y23.23 F3500.00 G1 X6.05 Y23.80 F3500.00 G1 X5.90 Y24.50 F3500.00 G1 X6.13 Y25.32 F3500.00 G1 X6.74 Y25.92 F3500.00 G1 X7.58 Y26.27 F3500.00 G1 X8.63 Y26.42 F3500.00 G1 X10.72 Y26.78 F3500.00 G1 X10.73 Y27.05 F3500.00 G1 X10.39 Y27.95 F3500.00 G1 X9.06 Y28.31 F3500.00 G1 X7.83 Y28.05 F3500.00 G1 X7.25 Y27.13 F3500.00 G1 X6.10 Y27.27 F3500.00 G1 X6.62 Y28.33 F3500.00 G1 X7.65 Y28.95 F3500.00 G1 X9.23 Y29.17 F3500.00 G1 X10.67 Y28.98 F3500.00 G1 X11.48 Y28.52 F3500.00 G1 X11.85 Y27.81 F3500.00 G1 X11.91 Y26.85 F3500.00 G1 X11.91 Y25.45 F3500.00 G1 X11.98 Y23.62 F3500.00 G1 X12.28 Y22.88 F3500.00 G1 X11.05 Y22.88 F3500.00 G1 X10.82 Y23.64 F3500.00 G1 X10.82 Y23.64 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X10.72 Y25.96 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X8.80 Y25.57 F3500.00 G1 X7.78 Y25.36 F3500.00 G1 X7.31 Y25.02 F3500.00 G1 X7.15 Y24.53 F3500.00 G1 X7.51 Y23.83 F3500.00 G1 X8.55 Y23.55 F3500.00 G1 X9.75 Y23.82 F3500.00 G1 X10.53 Y24.54 F3500.00 G1 X10.72 Y25.58 F3500.00 G1 X10.72 Y25.96 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X13.71 Y22.88 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X13.71 Y31.37 F3500.00 G1 X14.88 Y31.37 F3500.00 G1 X14.88 Y22.88 F3500.00 G1 X13.71 Y22.88 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X-17.49 Y8.04 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-17.49 Y14.20 F3500.00 G1 X-16.43 Y14.20 F3500.00 G1 X-16.43 Y13.26 F3500.00 G1 X-15.69 Y14.13 F3500.00 G1 X-14.93 Y14.34 F3500.00 G1 X-13.73 Y14.00 F3500.00 G1 X-14.13 Y13.03 F3500.00 G1 X-14.99 Y13.26 F3500.00 G1 X-15.68 Y13.05 F3500.00 G1 X-16.12 Y12.48 F3500.00 G1 X-16.32 Y11.27 F3500.00 G1 X-16.32 Y8.04 F3500.00 G1 X-17.49 Y8.04 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X-13.45 Y11.12 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-13.19 Y12.61 F3500.00 G1 X-12.38 Y13.65 F3500.00 G1 X-11.39 Y14.17 F3500.00 G1 X-10.20 Y14.34 F3500.00 G1 X-8.91 Y14.13 F3500.00 G1 X-7.87 Y13.51 F3500.00 G1 X-7.19 Y12.52 F3500.00 G1 X-6.96 Y11.21 F3500.00 G1 X-7.36 Y9.34 F3500.00 G1 X-8.53 Y8.28 F3500.00 G1 X-10.20 Y7.91 F3500.00 G1 X-11.52 Y8.11 F3500.00 G1 X-12.56 Y8.73 F3500.00 G1 X-13.23 Y9.75 F3500.00 G1 X-13.45 Y11.12 F3500.00 G1 X-13.45 Y11.12 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 2 segments.) G1 X-12.25 Y11.12 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-12.10 Y10.09 F3500.00 G1 X-11.67 Y9.35 F3500.00 G1 X-11.01 Y8.91 F3500.00 G1 X-10.20 Y8.76 F3500.00 G1 X-9.40 Y8.91 F3500.00 G1 X-8.75 Y9.35 F3500.00 G1 X-8.31 Y10.10 F3500.00 G1 X-8.17 Y11.16 F3500.00 G1 X-8.31 Y12.16 F3500.00 G1 X-8.75 Y12.89 F3500.00 G1 X-9.41 Y13.33 F3500.00 G1 X-10.20 Y13.47 F3500.00 G1 X-11.01 Y13.33 F3500.00 G1 X-11.67 Y12.89 F3500.00 G1 X-12.10 Y12.15 F3500.00 G1 X-12.25 Y11.12 F3500.00 G1 X-12.25 Y11.12 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X-5.57 Y8.04 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X-5.57 Y16.54 F3500.00 G1 X-4.40 Y16.54 F3500.00 G1 X-4.40 Y11.69 F3500.00 G1 X-1.62 Y14.20 F3500.00 G1 X-0.10 Y14.20 F3500.00 G1 X-2.75 Y11.91 F3500.00 G1 X0.17 Y8.04 F3500.00 G1 X-1.28 Y8.04 F3500.00 G1 X-3.57 Y11.19 F3500.00 G1 X-4.40 Y10.48 F3500.00 G1 X-4.40 Y8.04 F3500.00 G1 X-5.57 Y8.04 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(Polyline consisting of 1 segments.) G1 X0.63 Y9.88 F3500.00 M300 S30.00 (pen down) G4 P150 (wait 150ms) G1 X1.79 Y10.04 F3500.00 G1 X2.34 Y9.09 F3500.00 G1 X3.59 Y8.76 F3500.00 G1 X4.79 Y9.06 F3500.00 G1 X5.18 Y9.74 F3500.00 G1 X4.83 Y10.30 F3500.00 G1 X3.63 Y10.65 F3500.00 G1 X1.84 Y11.15 F3500.00 G1 X1.09 Y11.74 F3500.00 G1 X0.83 Y12.56 F3500.00 G1 X1.04 Y13.33 F3500.00 G1 X1.62 Y13.91 F3500.00 G1 X2.37 Y14.21 F3500.00 G1 X3.38 Y14.34 F3500.00 G1 X4.81 Y14.13 F3500.00 G1 X5.72 Y13.56 F3500.00 G1 X6.13 Y12.61 F3500.00 G1 X4.98 Y12.47 F3500.00 G1 X4.52 Y13.21 F3500.00 G1 X3.46 Y13.48 F3500.00 G1 X2.31 Y13.24 F3500.00 G1 X1.96 Y12.69 F3500.00 G1 X2.11 Y12.32 F3500.00 G1 X2.56 Y12.04 F3500.00 G1 X3.60 Y11.78 F3500.00 G1 X5.33 Y11.29 F3500.00 G1 X6.11 Y10.74 F3500.00 G1 X6.39 Y9.85 F3500.00 G1 X6.05 Y8.87 F3500.00 G1 X5.06 Y8.16 F3500.00 G1 X3.60 Y7.91 F3500.00 G1 X2.41 Y8.03 F3500.00 G1 X1.54 Y8.40 F3500.00 G1 X0.96 Y9.02 F3500.00 G1 X0.63 Y9.88 F3500.00 G1 X0.63 Y9.88 F3500.00 M300 S50.00 (pen up) G4 P150 (wait 150ms)
(end of print job) M300 S50.00 (pen up) G4 P150 (wait 150ms) M300 S255 (turn off servo) G1 X0 Y0 F3500.00 G1 Z0.00 F150.00 (go up to finished level) G1 X0.00 Y0.00 F3500.00 (go home) M18 (drives off)
That is not code that can be uploaded to an Arduino. That G code would be fed to a CNC machine using a G code sending program.
