Error while uploading
Please help I can't fix it. I have tried for about 1h now. Im going to turn on and off 2 relays with a ir remote and see the status on a lcd.
Error message:
C:\Users\kenny\OneDrive\Skrivbord\Arduino\Reef\Reef.ino: In function 'void loop()':
Reef:10:16: error: 'FF30CF' was not declared in this scope
#define code1 FF30CF // code received from button 1
C:\Users\kenny\OneDrive\Skrivbord\Arduino\Reef\Reef.ino:64:13: note: in expansion of macro 'code1'
case code1:
Reef:11:16: error: 'FF18E7' was not declared in this scope
#define code2 FF18E7 // code received from button 2
C:\Users\kenny\OneDrive\Skrivbord\Arduino\Reef\Reef.ino:81:13: note: in expansion of macro 'code2'
case code2:
Reef:12:16: error: 'FFA25D' was not declared in this scope
#define code3 FFA25D // code received from "ON/OFF button"
C:\Users\kenny\OneDrive\Skrivbord\Arduino\Reef\Reef.ino:97:13: note: in expansion of macro 'code3'
case code3:
exit status 1
The compiler is looking for a variable called FF30CF and not finding one.
Is this supposed to be a number in hex?
If so use 0xFF30CF
The 0x bit tells the compiler that what follows is a number.
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Grumpy_Mike:
If so use 0xFF30CF
Please read this:-
Thanks for the help.
Oh i forgot about that. My fault, I will erase the code
