ERROR with ARDUINO MEGA 2560!
Hello everyone,
I've been using the Arduino MEGA2560 and I am learning to use (using the 1.8.16 IDE) but, just now, I've encountered this issue:
Arduino:1.8.16 (Linux), Tarjeta:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
El Sketch usa 1536 bytes (0%) del espacio de almacenamiento de programa. El máximo es 253952 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 8183 bytes para las variables locales. El máximo es 8192 bytes.
avrdude: verification error, first mismatch at byte 0x036c
0xb8 != 0xf8
avrdude: verification error; content mismatch
The message appears every time I try to upload any kind of program to the Arduino so I think it's a board problem.
If you have any suggestions or need more information please reply!
Try another USB cable maybe?
As is new board, I have only one USB. But, is there any other option?
I think it's strange that it says "The Sketch uses 1536 bytes (0%) ..."
Are you saying that you have previously used the Mega without any issue, or did it show this problem out of the box?
What sketch are you trying to load?
I've written a very simple example, as follow:
pinMode(13, OUTPUT); // put your setup code here, to run once:
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(1000); // put your main code here, to run repeatedly:
The sketch uses less than 1% of the available flash. It could simply be due to the way the integer percentage is reported.
Maybe it could be related to the port settings? Because when I want to select the port option it only appears in Tools> Ports> "dev / USBo"
