Hello,
I have an Arduino Pro Mini 3.3 V and I would like to measure temperature and humidity with a Sensirion sensor, the SHT15 or 75. I have conected de DATA to pin 2 and CLOCK to 3, VCC and GND. I have tried without pull-up resistor and with one of 3 and 10 and it did not work. I have downloaded the library of the arduino webpage and with the NonBlocking example I always obtain the error of the ACK:
Error: No response (ACK) received from sensor!
I have also tried with short cables, less than 30 cm.
Do you what is the problem?
Thank you!
- Example code for SHT1x or SHT7x sensors demonstrating blocking calls
- for temperature and humidity measurement in the setup routine and
- non-blocking calls in the main loop. The pin 13 LED is flashed as a
- background task while temperature and humidity measurements are made.
- Note that the status register read/write demonstration code places the
- sensor in low resolution mode. Delete it to stay in high res mode.
- This example contains two versions of the code: one that checks library
- function return codes for error indications and one that does not.
- The version with error checking may be useful in debuging possible
- connection issues with the sensor. A #define selects between versions.
#include <Sensirion.h>
#define ENA_ERRCHK // Enable error checking code
const byte dataPin = 2; // SHTxx serial data
const byte sclkPin = 3; // SHTxx serial clock
const byte ledPin = 13; // Arduino built-in LED
const unsigned long TRHSTEP = 10000UL; // Sensor query period
const unsigned long BLINKSTEP = 250UL; // LED blink period
Sensirion sht = Sensirion(dataPin, sclkPin);
unsigned int rawData;
float temperature;
float humidity;
float dewpoint;
byte ledState = 0;
byte measActive = false;
byte measType = TEMP;
unsigned long trhMillis = 0; // Time interval tracking
unsigned long blinkMillis = 0;
#ifdef ENA_ERRCHK
// This version of the code checks return codes for errors
byte error = 0;
byte stat;
pinMode(ledPin, OUTPUT);
delay(15); // Wait >= 11 ms before first cmd
// Demonstrate status register read/write
if (error = sht.readSR(&stat)) // Read sensor status register
logError(error);
Serial.print(“Status reg = 0x”);
Serial.println(stat, HEX);
if (error = sht.writeSR(LOW_RES)) // Set sensor to low resolution
logError(error);
if (error = sht.readSR(&stat)) // Read sensor status register again
logError(error);
// Demonstrate blocking calls
if (error = sht.measTemp(&rawData)) // sht.meas(TEMP, &rawData, BLOCK)
logError(error);
temperature = sht.calcTemp(rawData);
if (error = sht.measHumi(&rawData)) // sht.meas(HUMI, &rawData, BLOCK)
logError(error);
humidity = sht.calcHumi(rawData, temperature);
dewpoint = sht.calcDewpoint(humidity, temperature);
logData();
unsigned long curMillis = millis(); // Get current time
// Rapidly blink LED. Blocking calls take too long to allow this.
if (curMillis - blinkMillis >= BLINKSTEP) { // Time to toggle the LED state?
ledState ^= 1;
digitalWrite(ledPin, ledState);
blinkMillis = curMillis;
// Demonstrate non-blocking calls
if (curMillis - trhMillis >= TRHSTEP) { // Time for new measurements?
measActive = true;
measType = TEMP;
if (error = sht.meas(TEMP, &rawData, NONBLOCK)) // Start temp measurement
logError(error);
trhMillis = curMillis;
if (measActive && (error = sht.measRdy())) { // Check measurement status
if (error != S_Meas_Rdy)
logError(error);
if (measType == TEMP) { // Process temp or humi?
measType = HUMI;
temperature = sht.calcTemp(rawData); // Convert raw sensor data
if (error = sht.meas(HUMI, &rawData, NONBLOCK)) // Start humi measurement
logError(error);
measActive = false;
humidity = sht.calcHumi(rawData, temperature); // Convert raw sensor data
logData();
#else // If ENA_ERRCHK is not defined
// This code is the same as above but without error checking
byte stat;
byte error = 0;
sht.readSR(&stat); // Read sensor status register
sht.writeSR(LOW_RES); // Set sensor to low resolution
sht.readSR(&stat); // Read sensor status register again
sht.measTemp(&rawData); // sht.meas(TEMP, &rawData, BLOCK)
sht.measHumi(&rawData); // sht.meas(HUMI, &rawData, BLOCK)
logData();
ledState ^= 1;
measActive = true;
measType = TEMP;
sht.meas(TEMP, &rawData, NONBLOCK); // Start temp measurement
if (measActive && sht.measRdy()) { // Check measurement status
measType = HUMI;
sht.meas(HUMI, &rawData, NONBLOCK); // Start humi measurement
measActive = false;
logData();
#endif // End of non-error-checking example
void logData() {
Serial.print(“Temperature = “); Serial.print(temperature);
Serial.print(” C, Humidity = “); Serial.print(humidity);
Serial.print(” %, Dewpoint = “); Serial.print(dewpoint);
Serial.println(” C”);
// The following code is only used with error checking enabled
void logError(byte error) {
switch (error) {
case S_Err_NoACK:
Serial.println(“Error: No response (ACK) received from sensor!”);
case S_Err_CRC:
Serial.println(“Error: CRC mismatch!”);
case S_Err_TO:
Serial.println(“Error: Measurement timeout!”);
default:
Serial.println(“Unknown error received!”);
