[Error with Code. Please HELP] Water Level Sensor using HC-SR04
I 'm trying to make a water level sensor with LEDs and Arduino uno to indicate the level of water in a tank. I tried writing this code but im getting a error. I want the all three leds to light up when the tank is filled (less distance).
I followed this tutorial but the code it had was showing 0 for the sensor value constantly.
Here is my code
#include <Ultrasonic.h>
#define TRIGGER_PIN  6
#define ECHO_PIN     7
Ultrasonic ultrasonic(TRIGGER_PIN, ECHO_PIN);
  pinMode(13,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(11,OUTPUT);
  float cmMsec, inMsec;
  long microsec = ultrasonic.timing();
  cmMsec = ultrasonic.convert(microsec, Ultrasonic::CM);
  inMsec = ultrasonic.convert(microsec, Ultrasonic::IN);
  Serial.print("MS: ");
  Serial.print(microsec);
  Serial.print(", CM: ");
  Serial.print(cmMsec);
  Serial.print(", IN: ");
  Serial.println(inMsec);
void led () {
 digitalWrite(13,LOW);
 digitalWrite(12,LOW);
 digitalWrite(11,LOW);
 if (cmMsec > 20) {
  digitalWrite(13,HIGH);
 if (cmMsec >=20 and cmMsec >= 10) {
  digitalWrite(12,HIGH);
 if (cmMsec < 10) {
  digitalWrite(11,HIGH);
Your code appears to have too many }
