Error with compiling code
Can anyone help on how I can fix this error?
this the error message:
13x388.iz343\sketch_mar4a\sketch_mar4a.ino:6:10: fatal error: Adafruit_NeoPixel.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: Adafruit_NeoPixel.h: No such file or directory
this is the code:
// NeoPixel test program showing use of the WHITE channel for RGBW
// pixels only (won't look correct on regular RGB NeoPixel strips).
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN 8
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 24
// NeoPixel brightness, 0 (min) to 255 (max)
#define BRIGHTNESS 70 // Set BRIGHTNESS to about 1/5 (max = 255)
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
  // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  // Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  // END of Trinket-specific code.
  strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(BRIGHTNESS);
  // Fill along the length of the strip in various colors...
  colorWipe(strip.Color(255,   0,   0)     , 50); // Red
  colorWipe(strip.Color(  0, 255,   0)     , 50); // Green
  colorWipe(strip.Color(  0,   0, 255)     , 50); // Blue
  colorWipe(strip.Color(  0,   0,   0, 255), 50); // True white (not RGB white)
  whiteOverRainbow(75, 5);
  pulseWhite(5);
  rainbowFade2White(3, 3, 1);
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(wait);                           //  Pause for a moment
void whiteOverRainbow(int whiteSpeed, int whiteLength) {
  if(whiteLength >= strip.numPixels()) whiteLength = strip.numPixels() - 1;
  int      head          = whiteLength - 1;
  int      tail          = 0;
  int      loops         = 3;
  int      loopNum       = 0;
  uint32_t lastTime      = millis();
  uint32_t firstPixelHue = 0;
  for(;;) { // Repeat forever (or until a 'break' or 'return')
      if(((i >= tail) && (i <= head)) ||      //  If between head & tail...
         ((tail > head) && ((i >= tail) || (i <= head)))) {
        strip.setPixelColor(i, strip.Color(0, 0, 0, 255)); // Set white
      } else {                                             // else set rainbow
        int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
        strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
    strip.show(); // Update strip with new contents
    // There's no delay here, it just runs full-tilt until the timer and
    // counter combination below runs out.
    firstPixelHue += 40; // Advance just a little along the color wheel
    if((millis() - lastTime) > whiteSpeed) { // Time to update head/tail?
      if(++head >= strip.numPixels()) {      // Advance head, wrap around
        head = 0;
        if(++loopNum >= loops) return;
      if(++tail >= strip.numPixels()) {      // Advance tail, wrap around
        tail = 0;
      lastTime = millis();                   // Save time of last movement
void pulseWhite(uint8_t wait) {
  for(int j=0; j<256; j++) { // Ramp up from 0 to 255
    // Fill entire strip with white at gamma-corrected brightness level 'j':
    strip.fill(strip.Color(0, 0, 0, strip.gamma8(j)));
    strip.show();
    delay(wait);
  for(int j=255; j>=0; j--) { // Ramp down from 255 to 0
    strip.show();
    delay(wait);
void rainbowFade2White(int wait, int rainbowLoops, int whiteLoops) {
  int fadeVal=0, fadeMax=100;
  // Hue of first pixel runs 'rainbowLoops' complete loops through the color
  // wheel. Color wheel has a range of 65536 but it's OK if we roll over, so
  // just count from 0 to rainbowLoops*65536, using steps of 256 so we
  // advance around the wheel at a decent clip.
  for(uint32_t firstPixelHue = 0; firstPixelHue < rainbowLoops*65536;
    firstPixelHue += 256) {
      // Offset pixel hue by an amount to make one full revolution of the
      // color wheel (range of 65536) along the length of the strip
      // (strip.numPixels() steps):
      uint32_t pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
      // strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
      // optionally add saturation and value (brightness) (each 0 to 255).
      // Here we're using just the three-argument variant, though the
      // second value (saturation) is a constant 255.
      strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue, 255,
        255 * fadeVal / fadeMax)));
    strip.show();
    delay(wait);
    if(firstPixelHue < 65536) {                              // First loop,
      if(fadeVal < fadeMax) fadeVal++;                       // fade in
    } else if(firstPixelHue >= ((rainbowLoops-1) * 65536)) { // Last loop,
      if(fadeVal > 0) fadeVal--;                             // fade out
      fadeVal = fadeMax; // Interim loop, make sure fade is at max
  for(int k=0; k<whiteLoops; k++) {
    for(int j=0; j<256; j++) { // Ramp up 0 to 255
      strip.show();
    delay(1000); // Pause 1 second
    for(int j=255; j>=0; j--) { // Ramp down 255 to 0
      strip.show();
  delay(500); // Pause 1/2 second
Did you install the Adafruit Neopixel library?
Yes i have downloaded it now, but there's an upload error that says this:
avrdude: stk500_recv(): programmer is not responding.
That is a completely different problem.
Which Arduino are you using?
I am using this one Grove Beginner Kit for Arduino | Seeed Studio Wiki
It's an arduino uno
If you have the shield connected, take it off.
Disconnect the Uno for the computer, close the IDE and any other programs.
Then reconnect the Uno and re-start the IDE.
If you have another USB cable, try it.
I tried it again, but this error message still shows:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfe
Failed uploading: uploading error: exit status 1
If you push the reset button on the Uno does the LED blink about 3 times.
Did you select the right board and port in the IDE?
Yes, the LED blinks three times and I have selected the right board and port on the IDE
Well that is good, it means the microcontroller is good and operating.
Next you need to do a loopback test so we can tell what may be wrong
It' easy to do
https://support.arduino.cc/hc/en-us/articles/360020366520-How-to-do-a-loopback-test
I tried it on a different computer and there was no errors with uploading the code. I also tried the loopback test on the new computer and it worked. I tried to use a code I've used before that worked (it lights the LEDs up in different colours) but it wasn't working this time. I've wired it up exactly the same as the first time, but only the RX and TX parts on the board are lighting up.
this is the code
#ifdef __AVR__
#endif
#define LED_PIN 8
#endif
  pulseWhite(5);
  int      tail          = 0;
  int      loops         = 3;
  int      loopNum       = 0;
        head = 0;
        tail = 0;
    strip.show();
    delay(wait);
    strip.show();
    delay(wait);
    strip.show();
    delay(wait);
      strip.show();
      strip.show();
What do you mean "first time" ?
I thought it never work before since you did not have the library installed.
So exactly what are you doing?
The first time I did it was on a computer that already had the library installed but I didn't realise you had to install the library. I am using computers at school so I am not always able to get the same computer each time. I am trying to test LEDs that I have got, but they aren't working anymore when I upload the code. Sorry for any confusion
Are you using the exact same neopixels that you used before?
Yes they are exactly the same ones
At this point all I can say is recheck your connections.
Make sure all grounds are connected.
Check the voltage on the power supply for the neopixels.
