Error with definition of #define
I am trying to define a #define in Arduino but I have error on line 7, this is the error shown:
expected primary-expression before '{' token
This is my code:
unsigned long timeout_start;
unsigned long timeout_ms;
#define TIMEOUT_2000MS 2000
#define ERROR_TIMEOUT 1
#define TIMEOUT_START { timeout_start = millis(); }
#define TIMEOUT_CHECK { if (millis() - timeout_start > timeout_ms) return ERROR_TIMEOUT; }
  timeout_ms = TIMEOUT_2000MS;
  TIMEOUT_START
  while (!Serial.available() && TIMEOUT_CHECK) {
    delay(1);
Someone could tell me what is my mistake?
Not posting the error message.
That one
Hint: try the macro expansion manually.
This is the error:
sketch_nov04a\sketch_nov04a.ino: In function 'void setup()':
sketch_nov04a:7:23: error: expected primary-expression before '{' token
sketch_nov04a\sketch_nov04a.ino:13:33: note: in expansion of macro 'TIMEOUT_CHECK'
That is PART of the error message!
Here is my part of the answer :
All you need to do is change . . . .
What do YOU get when YOU expand the macro? Makes no sense to me.
I already made the change, but the error is still there, on line 8:
Here is the code:
if ( (millis() - timeout_start) > timeout_ms )
  TIMEOUT_START
    delay(1);
Here is the error message:
sketch_nov04a:8:1: error: expected unqualified-id before 'if'
sketch_nov04a:10:1: error: expected declaration before '}' token
exit status 1
Your concept of the macro as a pseudo function is all wrong.
Your definition of the macro is very wrong with a lack of line continuation operators , so it looks like you got off lightly.
What you see
What the compiler sees
That's what the expansion does.
#define TIMEOUT_CHECK ( (millis() - timeout_start) > timeout_ms )
Looks better to me
You CAN use your existing definition of TIMEOUT_CHECK but you have to use it as a statement. You can't put a statement in an expression. You could use it this way:
while (!Serial.available()) {
    TIMEOUT_CHECK
    delay(1);
