Error with GET request using wifi module 8266
I'm using the wifi module 8266-01 and I'm trying to make a GET on an apache server on the local network, but every time I make the request it returns 'busy'.
Following sequence of execution on the serial monitor:
AT+CWMODE=1
OK
AT+CIPSTART="TCP","192.168.1.7",80
CONNECT
OK
TP/1.1
ERROR
Host: 192.168.1.7
ERROR
ERROR
GET /climatempo/getData.php HTTP/1.1
Host: 192.168.1.7
busy
Code:
esp.print("AT+CIPSTART=\"TCP\",\"");
  esp.print(CF(server));
  esp.print("\",80");
  esp.print("\r\n");
  Serial.println(esp.readString());
  char getRequest[] = "GET /climatempo/getData.php HTTP/1.1\r\nHost: 192.168.1.7";
  String cmd = "AT+CIPSEND="+sizeof(getRequest);
  esp.println(cmd);
  esp.print("\r\n");
  if(esp.readString().indexOf(">")) {
    esp.print(getRequest);
    esp.print("\r\n");
    delay(5000);
    Serial.println(F(""));
  // encerra conexão
  esp.print("AT+CIPCLOSE");
  esp.print("\r\n");
After you run AT + CIPSEND it prints this:
TP/1.1
ERROR
Host: 192.168.1.7
ERROR
ERROR
I do not know if AT + CIPSEND should return something or if it is in error.
Is it that the busy one that appears is because of that mistake?
I'm trying to get the IPD + after the GET request with this while, but I still do not know how to get the returned value (data) and I did not find a way to do that.
if( esp.readString().indexOf("SEND OK")) {
      Serial.println(F("Packet sent"));
      while (esp.readString().indexOf("+IPD")) {
        String line = esp.readStringUntil("+IPD");
        if(esp.readString().indexOf("+IPD")) {
          Serial.println(F("Achou mesmo tche"));
And I changed the request address to this, with the address in my network is not working:
char getRequest[] = "GET / HTTP/1.1 \r\nHost: krebscode.eti.br\r\n";
How can I get the returned values ??
