Error with handing over an arry to a function
I I wrote a function, but I get this error:
o: In function `loop':
undefined reference to `check_touch(int, int, int*)
This is the code:
boolean check_touch(int X, int Y, int field[]);
void setup(){
void loop(){
  int mouseY = 21;
  int mouseX = 2;
  int main_button[] = {2,6,3,5};
  if(check_touch((int)mouseX,(int)mouseY,main_button)){
    //Do Something
boolean ckeck_touch(int X,int Y,int* field){
  if((X>field[0])&&(X<field[1])&&(Y>field[2])&&(Y<field[3])){
    return true;
  else{
    return false;
What is wrong? I can’t find the mistake.
Greetings
Philipp
boolean ckeck_touch
The Arduino IDE has a really handy feature for finding this sort of thing. If you type "ctrl-f", it pops up a dialogue. In the field labelled "Find:" enter the name of the thing that is in the error message (int his case "check_touch"), then click on "Find". If you don't find it where you expect it, you've found your bug!
To be a little clearer than AWOL... You have this function prototype:
boolean check_touch(int X, int Y, [glow]int field[][/glow]);
and this function definition:
boolean ckeck_touch(int X,int Y,[glow]int* field[/glow])
You are calling the array version, that you haven't defined.
Read it again PaulS, carefully.
The prototype and declaration are functionally identical.
Some of the spelling, however…
