system
January 25, 2012, 12:00am
1
Hey all, I am using the code exactly as shown here but I am getting the following error when trying to verify
http://arduino.cc/playground/Code/I2CPortExpanderAndLCDs
lcd_i2c.cpp: In function 'void setup()':
lcd_i2c:30: error: 'WriteLCD' was not declared in this scope
any ideas here?
mkwired
January 25, 2012, 12:53am
2
The WriteLCD
function isn't implemented. That's not your fault.
system
January 25, 2012, 1:35am
3
cool, any ideas how to fix it?
My guess would be to replace calls to WriteLCD
with WriteLCDByte
or with SendToLCD
but it's just a guess. I didn't write the code.
system
January 25, 2012, 2:33am
5
that is far beyond my comprehension. How did unusable code end up on the Arduino website?
cmiyc
January 25, 2012, 3:25am
6
WindowMaker:
Add the word "Byte" where you see the word "WriteLCD".
So WriteLCD(ADDR,'a'); would become WriteLCDByte(ADDR,'a');
WindowMaker:
Anyone can add pages to the Playground. Maybe whoever posted that page didn't proofread their own code.
I guess a question for you is, what module are you using? Are you sure that code will work with whatever you are using?
system
January 25, 2012, 3:26am
7
thanks for the explanation. when I add Byte, it goes to this error
lcd_i2c:32: error: 'class LCDI2C4Bit' has no member named 'WriteLCDByte'
Change setup in the example code to read:
Wire.begin(); // join i2c bus (address optional for master)
lcd.init();
lcd.printIn("test");
lcd.print('a');
lcd.clear();
lcd.print('c');
lcd.cursorTo(0,0);
lcd.printIn("0");
lcd.cursorTo(1,0);
lcd.printIn("1");
lcd.cursorTo(2,0);
lcd.printIn("2");
lcd.cursorTo(3,0);
lcd.printIn("3");
Then it compiles.
system
January 25, 2012, 4:05am
9
Yes it does! Awesome!
One final question
How do I find the device address? I am using the MCP23008 (i have more than one running), I have A0, A1, and A2 wired to 5v so my understanding would be that the address is 0100111. Do I just put that int he brackets at Wire.begin?
here is the datasheet
There is a I2C scanner here:
If you have more than one MCP23008 set the A0, A1, A2 to different combinations (eg. Gnd/5V/Gnd and so on).
This is the line you change:
int ADDR = 0xA7;
Since you want (say) 3 devices you could have:
LCDI2C4Bit lcd1 = LCDI2C4Bit(0b0100000,4,20);
LCDI2C4Bit lcd2 = LCDI2C4Bit(0b0100001,4,20);
LCDI2C4Bit lcd3 = LCDI2C4Bit(0b0100010,4,20);
That way you have three instances of the class with different addresses for each one. Although I think that does an unnecessary copy operation. How about:
LCDI2C4Bit lcd1 (0b0100000, 4, 20);
LCDI2C4Bit lcd2 (0b0100001, 4, 20);
LCDI2C4Bit lcd3 (0b0100010, 4, 20);
