Hi, I am trying to run this example sketches on an ESP32 which demonstrates the simultaneous use of microphone and speaker using a single I2S module.
The application transfers data from input to output, for this I want to configure the pins to my needs, but when I try to compile it, it throws me this error:
no matching function for call to 'I2SClass::setAllPins(int, int, int, int)'
how can I correct it?
Here the example code:
#include <I2S.h>
const long sampleRate = 16000;
const int bitsPerSample = 32;
uint8_t *buffer;
I2S.setAllPins(5, 25, 35, 26); // you can change default pins; order of pins = (CLK, WS, IN, OUT)
if(!I2S.setDuplex()){
Serial.println("ERROR - could not set duplex");
while(true){
vTaskDelay(10); // Cannot continue
if (!I2S.begin(I2S_PHILIPS_MODE, sampleRate, bitsPerSample)) {
Serial.println("Failed to initialize I2S!");
while(true){
buffer = (uint8_t*) malloc(I2S.getBufferSize() * (bitsPerSample / 8));
if(buffer == NULL){
Serial.println("Failed to allocate buffer!");
while(true){
Serial.println("Setup done");
I2S.read(buffer, I2S.getBufferSize() * (bitsPerSample / 8));
I2S.write(buffer, I2S.getBufferSize() * (bitsPerSample / 8));
