Error with ITEADLIB for Nextion display on Arduino MEGA 2560
Hello,
I want my Arduino MEGA 2560 to communicate with a Nextion display.
I've dowloaded the ITEADLIB (GitHub - itead/ITEADLIB_Arduino_Nextion).
Here is the beginning of the program :
#include <Nextion.h>
#define nextion Serial1
Nextion mynextion(nextion, 250000);
When I compile it, I get this error :
Compilation error: 'Nextion' does not name a type; did you mean 'nextion'?
I've tried using different versions of Arduino and libraries but it didn't resolve it.
Can someone help me please ? That would be very kind.
Florentin.
I have looked up some nextion-demo-examples.
In none of these examples is a code-line
If you have this code from a website you should post a link to this website.
Depending on what you want to do in the end with the display it might be easier
to
NOT
use the nextion-library.
you should post a detailed description of what you want to do in this project.
Here is a tutorial about nextion displays
best regards Stefan
Thank you for your answer Stefan !
Actually this is a code that is already working on an arduino mega connected to the same Nextion screen. The problem is that I don't have access to the pc that has been used to create the program anymore.
That been said, here is a link to a page where the command is used : https://github.com/bborncr/nextion/blob/master/examples/ReceiveMessages/ReceiveMessages.ino~
Best regards, Florentin
The error-message says that the library was not found you have to install this library on that computer you want to use for modifying/compiling the code.
It seems that this library is only available as a ZIP-library from here
Follow this tutorial to install the library
best regards Stefan
Thank you. I’ve already tried with this library and followed the tutorial. It still doesn’t work…
Best regards,
Florentin
Change compiler-options to maximum verbose output.
Then click compile again. If the compilation aborts click on copy error-messages and post the complete compiler-log as a code-section
Here it is :
FQBN: arduino:avr:mega
Using board 'mega' from platform in folder: C:\Users\Bureau\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Bureau\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp" -o nul
Alternative pour Nextion.h: [nextion-master]
ResolveLibrary(Nextion.h)
  -> candidates: [nextion-master]
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp" -o nul
Alternative pour SoftwareSerial.h: [SoftwareSerial@1.0]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [SoftwareSerial@1.0]
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp" -o nul
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master\\Nextion.cpp" -o nul
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp" -o "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\Bureau\\Documents\\Arduino\\libraries\\nextion-master" "-IC:\\Users\\Bureau\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp" -o "C:\\Users\\Bureau\\AppData\\Local\\Temp\\arduino\\sketches\\F27D04AA0CAB7AAC8D43526515CF23EC\\sketch\\sketch_aug16a.ino.cpp.o"
C:\Users\Bureau\AppData\Local\Temp\.arduinoIDE-unsaved2023716-23312-gzl0h4.uuztl\sketch_aug16a\sketch_aug16a.ino:3:34: error: no matching function for call to 'Nextion::Nextion(HardwareSerial&, long int)'
In file included from C:\Users\Bureau\AppData\Local\Temp\.arduinoIDE-unsaved2023716-23312-gzl0h4.uuztl\sketch_aug16a\sketch_aug16a.ino:1:0:
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:65:3: note: candidate: Nextion::Nextion(SoftwareSerial&, uint32_t)
   Nextion(SoftwareSerial &next, uint32_t baud);//Constructor
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:65:3: note:   no known conversion for argument 1 from 'HardwareSerial' to 'SoftwareSerial&'
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:63:5: note: candidate: Nextion::Nextion()
     Nextion(){};//Empty contructor
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:63:5: note:   candidate expects 0 arguments, 2 provided
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:54:7: note: candidate: constexpr Nextion::Nextion(const Nextion&)
 class Nextion{
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:54:7: note:   candidate expects 1 argument, 2 provided
C:\Users\Bureau\Documents\Arduino\libraries\nextion-master/Nextion.h:54:7: note: candidate: constexpr Nextion::Nextion(Nextion&&)
Utilisation de la bibliothèque nextion-master prise dans le dossier: C:\Users\Bureau\Documents\Arduino\libraries\nextion-master (héritage)
Utilisation de la bibliothèque SoftwareSerial version 1.0 dans le dossier: C:\Users\Bureau\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
exit status 1
Compilation error: no matching function for call to 'Nextion::Nextion(HardwareSerial&, long int)'
Well I downloaded the ZIP-library from here
https://github.com/bborncr/nextion/tree/master
installed this ZIP-library
and then compiled this demo-code
https://raw.githubusercontent.com/bborncr/nextion/master/examples/ReceiveMessages/ReceiveMessages.ino
Which is the pure-textversion of this website
The compilation was successfull.
BUT
In the compiler-log this nextion-library is used
Alternatives for Nextion.h: [ITEADLIB_Arduino_Nextion-master nextion]
  -> candidates: [ITEADLIB_Arduino_Nextion-master nextion]
Alternatives for Nextion.h: [ ITEADLIB_Arduino_Nextion-master nextion]
This means the nextion-library that you linked to
https : // github.com/bborncr /nextion/tree/master
is the wrong one
Your compiler used this library
Alternative pour Nextion.h: [ nextion-master ]
wrong one: Nextion.h: [nextion-master]
right one: Nextion.h: [ITEADLIB_Arduino_Nextion-master nextion]
EDIT
So my suggestion is that you delete the folder
C:\Users\Bureau\Documents\Arduino\libraries\ nextion-master
very strange compiler-behaviour
without the bborncr-nextion-library I got the same compiler-error as you
After re-installing the bborncr-nextion-library the compiler-log says it is using the
ITEADLIB_Arduino_Nextion-master-library.
Never encountered something like this before! Huh ?!?
check after installing if you have a folder
C:\Users\Bureau\Documents\Arduino\libraries\ ITEADLIB_Arduino_Nextion-master
I have found this path in these lines of the compiler-log that name the errors that occurred
etc. etc. etc.
 class Nextion{
With successful compiling the compiler-log looks like this
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_383896 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_383896 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino
Using board 'mega' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0 EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3]
  -> candidates: [SoftwareSerial@1.0 EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\Arduino-funktioniert\\arduino-1.8.19-windows-2022-01-30\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp.o"
Compiling libraries...
Compiling library "SoftwareSerial"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o"
Compiling library "nextion"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\nextion\\Nextion.cpp.o"
F:\myData\Arduino\libraries\nextion\Nextion.cpp: In member function 'unsigned int Nextion::getComponentValue(String)':
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:25: warning: left shift count >= width of type [-Wshift-count-overflow]
     value = (temp[4] << 24) | (temp[3] << 16) | (temp[2] << 8) | (temp[1]);//Little-endian convertion
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:43: warning: left shift count >= width of type [-Wshift-count-overflow]
Compiling core...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_pulse.S.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\hooks.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\hooks.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_analog.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WInterrupts.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_digital.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_pulse.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_shift.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\CDC.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\IPAddress.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\PluggableUSB.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Print.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Print.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Stream.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Tone.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\USBCore.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WMath.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\WString.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WString.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\main.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\main.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\abi.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\abi.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino\\new.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\new.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_pulse.S.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WInterrupts.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\hooks.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_analog.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_digital.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_pulse.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\wiring_shift.c.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\CDC.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\IPAddress.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\PluggableUSB.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Print.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Stream.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\Tone.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\USBCore.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WMath.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\WString.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\abi.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\main.cpp.o"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\core.a" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\core\\new.cpp.o"
Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543\core\core_arduino_avr_mega_cpu_atmega2560_cbf59aea3d48275ca0a46a930fe90002.a
Linking everything together...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\nextion\\Nextion.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/core\\core.a" "-LC:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896" -lm
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.eep"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.hex"
Mehrere Bibliotheken wurden für "Nextion.h" gefunden
 Benutzt: F:\myData\Arduino\libraries\nextion
 Nicht benutzt: F:\myData\Arduino\libraries\ITEADLIB_Arduino_Nextion-master
Mehrere Bibliotheken wurden für "SoftwareSerial.h" gefunden
 Benutzt: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
 Nicht benutzt: E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries\EspSoftwareSerial
 Nicht benutzt: F:\myData\Arduino\libraries\EspSoftwareSerial
Bibliothek SoftwareSerial in Version 1.0 im Ordner: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial  wird verwendet
Bibliothek nextion im Ordner: F:\myData\Arduino\libraries\nextion (legacy) wird verwendet
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf"
Der Sketch verwendet 7542 Bytes (2%) des Programmspeicherplatzes. Das Maximum sind 253952 Bytes.
Globale Variablen verwenden 342 Bytes (4%) des dynamischen Speichers, 7850 Bytes für lokale Variablen verbleiben. Das Maximum sind 8192 Bytes.
best regards Stefan
