Error with multiple message with the RadioHead librairy
Hello
I’m using the RadioHead library [1] to have a communication between two Arduino with an NRF24L01+ wireless module. If I send one (1) message, everything works fine. But when I try to send four (4) messages of 15 Bytes, nothing works.
I tried everything in the last two days but I can’t have anything working.
Do someone have an idea?
There is my code
vserver.ino
#include <Speck.h>
#include <RH_NRF24.h>
#include <RHEncryptedDriver.h>
#include <RHReliableDatagram.h>
Speck CIPHER;
const unsigned char ENCRYPTION_KEY[16] =
    {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16};
const int NRF_24_CE_PIN = 9, NRF_24_CSN_PIN = 10,
          SERVER_ADDRESS = 1, CLIENT_ADDRESS = 2,
          MANAGER_TIMEOUT = 5000;
RH_NRF24 NRF24(NRF_24_CE_PIN, NRF_24_CSN_PIN);
RHEncryptedDriver NRF24_DRIVER(NRF24, CIPHER);
RHReliableDatagram NRF24_MANAGER(NRF24_DRIVER, SERVER_ADDRESS);
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
uint8_t from;
    if (!NRF24_MANAGER.init())
        Serial.println("NRF24 initialization failed");
    NRF24_MANAGER.setTimeout(MANAGER_TIMEOUT);
    CIPHER.setKey(ENCRYPTION_KEY, sizeof(ENCRYPTION_KEY));
    if (NRF24_MANAGER.available()) {
        if (NRF24_MANAGER.recvfromAck(buf, &len, &from)) {
            if(strcmp((char*)buf, "GET_DATA")  == 0) {
                uint8_t data0[] = "AAAAAAAAAAAAAA";
                uint8_t data1[] = "BBBBBBBBBBBBBB";
                uint8_t data2[] = "CCCCCCCCCCCCCC";
                uint8_t data3[] = "DDDDDDDDDDDDDD";
                if (NRF24_MANAGER.sendtoWait(data0, sizeof(data0), from)) {
                    Serial.println("sendtoWait 0 OK");
                    if (NRF24_MANAGER.sendtoWait(data1, sizeof(data1), from)) {
                        Serial.println("sendtoWait 1 OK");
                        if (NRF24_MANAGER.sendtoWait(data2, sizeof(data2), from)) {
                            Serial.println("sendtoWait 2 OK");
                            if (NRF24_MANAGER.sendtoWait(data3, sizeof(data3), from)) {
                                Serial.println("sendtoWait 3 OK");
                            else Serial.println("sendtoWait 3 failed");
                        else Serial.println("sendtoWait 2 failed");
                    else Serial.println("sendtoWait 1 failed");
                else Serial.println("sendtoWait 0 failed");
vclient.ino
#include <Speck.h>
Speck CIPHER;
          SERVER_ADDRESS = 1, CLIENT_ADDRESS = 2;
RHReliableDatagram NRF24_MANAGER(NRF24_DRIVER, CLIENT_ADDRESS);
uint8_t from;
bool GET_DATA = false;
    cli();
    TCCR1A = 0;
    TCCR1B = 0;
    TCNT1  = 0;
    OCR1A = 15624;
    TCCR1B |= (1 << WGM12);
    TCCR1B |= (1 << CS12) | (1 << CS10);
    TIMSK1 |= (1 << OCIE1A);
    sei();
    if(GET_DATA) {
        uint8_t data[] = "GET_DATA";
        if (NRF24_MANAGER.sendtoWait(data, sizeof(data), SERVER_ADDRESS)) {
            if (NRF24_MANAGER.recvfromAckTimeout(buf, &len, 1000, &from)) {
                Serial.print("Received 0: ");
                Serial.println((char*)buf);
                    Serial.print("Received 1: ");
                        Serial.print("Received 2: ");
                            Serial.print("Received 3: ");
                            Serial.println("EVERYTHING OK! YEAH!");
                        } else Serial.println("Fail 3");
                    } else Serial.println("Fail 2");
                } else Serial.println("Fail 1");
            } else Serial.println("Fail 0");
        GET_DATA = false;
ISR(TIMER1_COMPA_vect) {
    static int seconds = 0;
    if(++seconds == 10) {
        GET_DATA = true;
        seconds = 0;
Thanks
[1] RadioHead: RadioHead Packet Radio library for embedded microprocessors
vserver.ino (2.17 KB)
vclient.ino (2.41 KB)
I tried to add a delay but that didn't work too
