Error with my arduino
Hey:
I bought my first robot callled three-wheeled smart cart kit. With the program i have this to put in my programing
#include <SPI.h>
#include "RF24.h"
RF24 radio(9, 10); // define the object to control NRF24L01
const byte addresses[6] = "Free1";// define communication address which should correspond to remote control
// servo
#include <Servo.h>
Servo dirServo; // define servo to control turning of smart car
const int dirServoPin = 2; // define pin for signal line of the last servo
byte dirServoOffset = 0; // define a variable for deviation(degree) of the servo
// motor
const int dirAPin = 7, // define pin used to control rotational direction of motor A
pwmAPin = 6, // define pin for PWM used to control rotational speed of motor A
dirBPin = 4, // define pin used to control rotational direction of motor B
pwmBPin = 5, // define pin for PWM used to control rotational speed of motor B
snsAPin = A0, // define pin for detecting current of motor A
snsBPin = A1, // define pin for detecting current of motor B
buzzerPin = 3, // define pin for buzzer
ledRPin = A3, // define R pin of RGBLED
ledGPin = A4, // define G pin of RGBLED
ledBPin = A5; // define B pin of RGBLED
const byte motorSpeed = 255; // define motor speed(0-255)
#define FORWARD LOW
#define BACKWARD HIGH
// wireless communication
int dataRead[8]; // define array used to save the read data
const unsigned long wirelessOvertime = 200; // define communication overtime(ms)
unsigned long lastReceivedSignal; // define a variable to save the time(ms) of last received the signal
// serial port
// NRF24L01
radio.begin(); // initialize RF24
radio.setPALevel(RF24_PA_LOW); // set power amplifier (PA) level
radio.setDataRate(RF24_1MBPS); // set data rate through the air
radio.setRetries(0, 15); // set the number and delay of retries
radio.openWritingPipe(addresses); // open a pipe for writing
radio.openReadingPipe(1, addresses);// open a pipe for reading
radio.startListening(); // start monitoringtart listening on the pipes opened
// servo
dirServo.attach(dirServoPin); // attaches the servo on dirServoPin to the servo object
// motor
pinMode(dirAPin, OUTPUT); // set dirAPin to output mode
pinMode(pwmAPin, OUTPUT); // set pwmAPin to output mode
pinMode(dirBPin, OUTPUT); // set dirBPin to output mode
pinMode(pwmBPin, OUTPUT); // set pwmBPin to output mode
// pin
pinMode(buzzerPin, OUTPUT); // set buzzerPin to output mode
pinMode(ledRPin, OUTPUT); // set ledRPin to output mode
pinMode(ledGPin, OUTPUT); // set ledGPin to output mode
pinMode(ledBPin, OUTPUT); // set ledBPin to output mode
digitalWrite(ledRPin, HIGH); // turn off R LED
digitalWrite(ledGPin, HIGH); // turn off G LED
digitalWrite(ledBPin, HIGH); // turn off B LED
// read radio data
if ( radio.available()) { // if receive the data
while (radio.available()) { // read all the data
radio.read(dataRead, sizeof(dataRead)); // read data
// calculate the angle of turning
int dirServoDegree = map(dataRead[2], 0, 1023, 135, 45) - (dataRead[0] - 512) / 25;
// calculate speed of moving
int motorSpd = dataRead[3] - 512 + (dataRead[1] - 512) / 10;
bool motorDir = motorSpd > 0 ? BACKWARD : FORWARD;
motorSpd = abs(constrain(motorSpd, -512, 512));
motorSpd = map(motorSpd, 0, 512, 0, motorSpeed);
// control the turning and moving of the car
ctrlCar(dirServoDegree, motorDir, motorSpd);
// control the buzzer
if (!dataRead[4])
tone(buzzerPin, 2000);
noTone(buzzerPin);
// control the RGB LED
digitalWrite(ledRPin, dataRead[5]);
digitalWrite(ledGPin, dataRead[6]);
digitalWrite(ledBPin, dataRead[7]);
// save the time of last received the wireless signal
lastReceivedSignal = millis();
else {
// if lose wireless signal for a long time
if (millis() - lastReceivedSignal >= wirelessOvertime) {
// stop the car
analogWrite(pwmAPin, 0);
analogWrite(pwmBPin, 0);
// turn off the buzzer
noTone(buzzerPin);
// turn off the RGB LED
// send motor current to serial port Serial.print(iMotorB);
Serial.println(" A");
im noob so i thing that if a put this in my robot i can move it but when i going to put it said this error:
Arduino:1.8.4 (Windows 7), Tarjeta:"Arduino/Genuino Uno"
C:\Users\Jhonandretti\Desktop\arduino\Freenove_Three-wheeled_Smart_Car_Kit_for_Arduino-master\Sketches\Remote_control\Remote_control_Car\Remote_control_Car.ino:2:18: fatal error: RF24.h: No such file or directory
#include "RF24.h"
compilation terminated.
exit status 1
Error compilando para la tarjeta Arduino/Genuino Uno.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
please help
The RF24 library is not installed or not installed properly.
Why did you not read the "How to use the forum-please read" stickies? You will get better help if you follow the forum guidelines.
what is rf24
Is Google broken for you? The third line of the program should give you a hint (RF24 radio(9, 10)). If the library does not show up in library manager it can be found here.
