Error with nRF24L01 and HC-SR04
Hello,
I have written 2 programs for 2 Arduino .
This will send a pulse or send or receive a HIGH signal through 2 nRF24L01 .
Unfortunately this does not work completely .
Therefore, I hope for your help .
Enclosed the programs
Arduino One:
#include <NewPing.h>        //Importiere HC-SR04 Bibliothek
#include <SPI.h>            //Importiere SPI Bibliothek
#include <nRF24L01.h>       //nRF24L01 Bibliotheken
#include <RF24.h>           //nRF24L01 Bibliotheken
//HC-SR04 Zuweisungen
#define TRIGGER_PIN  6   //Arduino Pin 6 --> Trigger-Pin HC-SR04
#define ECHO_PIN     5  //Arduino Pin --> Echo-Pin HC-SR04
#define MAX_DISTANCE 100 //Maximale Distanz in Zentimeter.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
//nRF24L01 Zuweisungen
#define CE_PIN   9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t   deviceID = 0xE8E8F0F0E1LL; // Define the ID for this slave
int valChange = 1;
unsigned long aktuelleMillis;                     //Aktuelle Millisekunden
unsigned long vergangeneMillis;                   //Vergangene Millisekunden
unsigned long txIntervalMillis = 100;             //TX Millisekunden Interval
unsigned long Start, Stop, Zeit;
unsigned long HCMillis = 0;                       //Vergange Zeit HC-SR04
unsigned long HCInterval = 30;                    //HC-SR04 Intervall Zeit in Millisekunden
int Aktiv = 0;
RF24 radio(CE_PIN, CSN_PIN);
int dataReceived[2];
int ackData[2] = {12,23};
void displayResult()
  float h,m,s,ms;
  unsigned long over;
  Zeit=Stop-Start;
  h=int(Zeit/3600000);
  over=Zeit%3600000;
  m=int(over/60000);
  over=over%60000;
  s=int(over/1000);
  ms=over%1000;
  Serial.print("Vergangene Zeit RAW: ");
  Serial.println(Zeit);
  Serial.print("Vergangene Zeit: ");
  Serial.print(h,0);
  Serial.print("h ");
  Serial.print(m,0);
  Serial.print("m ");
  Serial.print(s,0);
  Serial.print("s ");
  Serial.print(ms,0);
  Serial.println("ms");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.openReadingPipe(1,deviceID);
    radio.enableAckPayload();
    radio.writeAckPayload(1, ackData, sizeof(ackData));
    radio.startListening();
        Serial.println("Stoppuhr Empfaenger bereit");
  aktuelleMillis = millis();
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
    if ( radio.available() ) {
        radio.read( dataReceived, sizeof(dataReceived) );
    if (dataReceived[0] == 1 && Aktiv == 0)
    Start=millis();
    dataReceived[0] = 0;
    Aktiv = 1;
    delay(200);
    Serial.println("Stoppuhr gestartet.");
    Serial.println(Aktiv);
    if (Aktiv == 1 && uS / US_ROUNDTRIP_CM <70)
    Stop=millis();
    Aktiv = 0;
    delay(200);
    displayResult();
Arduino Two:
#define CE_PIN   9
#define CSN_PIN 10
// These are the IDs of each of the slaves
const uint64_t slaveID[1] = {0xE8E8F0F0E1LL} ;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
int dataToSend[1];
int Sende = 0;
unsigned long txIntervalMillis = 1000;             //TX Millisekunden Interval
unsigned long HCInterval = 40;                    //HC-SR04 Intervall Zeit in Millisekunden
int txVal = 0;
int ackMessg[6];
byte ackMessgLen = 4; // NB this 4 is the number of bytes in the 2 ints that will be recieved
    Serial.println("Track Control Starting");
    radio.begin();
    radio.setRetries(4,15); // delay, count
    if (aktuelleMillis - vergangeneMillis >= txIntervalMillis)
    radio.openWritingPipe(slaveID[0]);                       // calls the first slave
                                                             // there could be a FOR loop to call several slaves in turn
    if (uS / US_ROUNDTRIP_CM <=20){             // Distanz größer als 10cm und kleiner als 70cm
    dataToSend[0] = 1; //
    bool rslt;
    rslt = radio.write( dataToSend, sizeof(dataToSend) );
    dataToSend[0] = 0; //
    bool rslt;
    if ( radio.isAckPayloadAvailable() ) {
        radio.read(ackMessg,ackMessgLen);
        Serial.print("Acknowledge received: ");
        Serial.print(ackMessg[0]);
    vergangeneMillis = millis();
    Serial.println(dataToSend[0]);
The code on each end does something. You left that part out. You expect the code on each end to do something. You left that part out, too.
We do not know what help you need.
OK,
The Problem is, that the Arduino One doesnt send a Signal when the HC-SR04 gives the value. Or the second Arduino doesnt receive it. But this is my problem, because i doesnt know it.
What do your Serial.print()s tell you is happening? Does Arduino One ever get the data needed to set Aktiv to 1? Does the ping sensor ever get a value of less than 70?
Arduino One doesnt get the data to set Aktiv to 1. But Arduino Two dataToSend[0] will set to 1.
Markus1995: Arduino One doesnt get the data to set Aktiv to 1. But Arduino Two dataToSend[0] will set to 1.
But it sends the data only if it measures a distance of less than 21 centimeters, and the pipe is opened for writing (which happens only if aktuelleMillis - vergangeneMillis >= txIntervalMillis, which seems unlikely, as vergangeneMillis is set to aktuelleMillis at the end of each pass through loop()).
properly my fault is there....
can i open the pipe constantly?
I would think that you would open the pipe for writing when you have something to write.
The pair of programs in this link may give you some ideas.
...R
