The error is that it says that it has to few arguments , but I didn’t edited it?
The full code is to long, so I’m just going to give a piece where the printButton function is used:
if (refreshAll)
printHeader("Test LED Schema");
myGLCD.fillRect (1, 15, 318, 37); //clear "Test in Progress" Banner
myGLCD.setColor(64, 64, 64); //Draw Dividers in Grey
myGLCD.drawRect(0, 196, 319, 194); //Bottom Horizontal Divider
printButton("<< TERUG >>", back[0], back[1], back[2], back[3], SMALL);
printButton("ANNULEER", canC[0], canC[1], canC[2], canC[3], SMALL);
printButton ("", stsT[0], stsT[1], stsT[2], stsT[3], true); //start/stop
printButton ("-10s", tenM[0], tenM[1], tenM[2], tenM[3], true); //-10s
printButton ("+10s", tenP[0], tenP[1], tenP[2], tenP[3], true); //+10s
myGLCD.print("START", stsT[0]+6, stsT[1]+15);
myGLCD.print("TEST", stsT[0]+15, stsT[1]+40);
min_cnt=0;
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect (1, 15, 318, 99); //clear test results if any
myGLCD.fillRect (1, 187, 318, 227); //clear the "Back" and "Cancel" Buttons
myGLCD.setColor(0, 0, 255);
myGLCD.fillRect(stsT[0]+5, stsT[1]+5, stsT[2]-5, stsT[3]-40); //clear 'start'
setFont(LARGE, 255, 255, 255, 0, 0, 255);
myGLCD.print("STOP", stsT[0]+15, stsT[1]+15);
myGLCD.setColor(255, 0, 0);
myGLCD.drawRoundRect (stsT[0], stsT[1], stsT[2], stsT[3]); //red button during test
setFont(LARGE, 255, 255, 255, 255, 0, 0);
myGLCD.print("Test in Progress", CENTER, 16);
setFont(SMALL, 255, 255, 255, 0, 0, 0);
myGLCD.print("TIME:", 52, 40);
myGLCD.print("LIGHT OUTPUT (0--255):", 140, 40);
while (LEDtestTick) //test LED and speed up time
if (myTouch.dataAvailable())
{ processMyTouch();}
if (currentMillis - previousMillisLED > 500) //change time every 0.5s
previousMillisLED = currentMillis;
min_cnt++;
String oldvalue, twelveHR, hrs, HOURS, hrsPM, mins, Minutes, AMPM;
int hours = min_cnt/60;
int minut = min_cnt%60;
if (hours<12){AMPM="AM";} //Adding the AM/PM suffix
else{AMPM="PM";}
HOURS=hours;
hrsPM=hours-12;
if (hours==0){hrs=12;}
else { if ((hours>=1)&&(hours<=9)){hrs=" "+HOURS;} //keep hours in place
else { if ((hours>=13)&&(hours<=21)){hrs=" " +hrsPM;} //convert to 12HR
else { if ((hours>=22)&&(hours<24)){hrs=hrsPM;}
else { if (hours==24){hrs=12;}
else{hrs=HOURS;}}}}}
mins=minut; //add zero to minutes
if ((minut>=0)&&(minut<=9)){Minutes="0"+mins;}
else {Minutes=mins;}
oldvalue=twelveHR;
twelveHR=hrs+':'+Minutes;
if ((oldvalue!=twelveHR)||refreshAll)
{char bufferCount[9];
twelveHR.toCharArray(bufferCount,9);
setFont(LARGE, 255, 255, 255, 0, 0, 0);
myGLCD.print(bufferCount, 7, 55);
char bufferAMPM[3];
AMPM.toCharArray(bufferAMPM,3);
myGLCD.print(bufferAMPM, 90, 55);
setFont(SMALL, 0, 150, 0, 0, 0, 0);
String sled = "Groen: " + String(grled_out) + " " + " ";
char bufferS[11];
sled.toCharArray(bufferS, 11);
myGLCD.print(bufferS, 145, 55);
setFont(SMALL, 255, 0, 0, 0, 0, 0);
String rled = "Groen: " + String(rled_out) + " " + " ";
char bufferR[11];
rled.toCharArray(bufferR, 11);
myGLCD.print(bufferR, 145, 67);
String wled = "Wit: " + String(wled_out) + " " + " ";
char bufferW[11];
wled.toCharArray(bufferW, 11);
myGLCD.print(bufferW, 145, 79);
setFont(SMALL, 9, 184, 255, 0, 0, 0);
String bled = "Blauw: " + String(bled_out) + " " + " ";
char bufferB[11];
bled.toCharArray(bufferB, 11);
myGLCD.print(bufferB, 235, 55);
setFont(SMALL, 58, 95, 205, 0, 0, 0);
String rbled = "Royal: " + String(rbled_out) + " " + " ";
char bufferRB[11];
rbled.toCharArray(bufferRB, 11);
myGLCD.print(bufferRB, 235, 67);
setFont(SMALL, 224, 102, 255, 0, 0, 0);
String uvled = "Uv: " + String(uvled_out) + " " + " ";
char bufferUV[11];
uvled.toCharArray(bufferUV, 11);
myGLCD.print(bufferUV, 235, 79);
LED_levels_output();
checkTempC();
TimeDateBar();
