Error with TimeSerial Example
I am sure that is not the problem. Which Serial.print do you suggest I replace? In the code or in the library? I replaced the prints with writes and got 30 lines of errors, more than the frist time. This is an example code off the web site using the supplied library, it should work the first time.
