Ok so basically what I am doing is reading data from the joystick connection to a nano and sending it through nRF24L01 (PA) and sending to arduino uno with just a nRF24L01 I am able to send my data but the output I get out of my uno is 192 for all values. but the output for the values in nano is correct. I tried a lot but couldn't understand the problem.
Transmitter code
#define Pitch A0
#define Roll A1
#define Yaw A2
int pitch;
int roll;
int yaw;
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8); // CE CSN
const byte Address[6] = "00009";
void setupTransmitter(void)
radio.begin();
radio.openWritingPipe(Address);
radio.setPALevel(RF24_PA_MAX);
radio.stopListening(); // set as transmitter
Serial.println("Transmitting");
void sendData(int *pPitch, int *pRoll, int *pYaw)
radio.write(pPitch, sizeof(*pPitch));
radio.write(pRoll, sizeof(*pRoll));
radio.write(pYaw, sizeof(*pYaw));
Serial.print("Transmitting Data : ");
void readJoysticks(int *pPitch, int *pRoll, int *pYaw)
*pPitch = analogRead(Pitch);
*pRoll = analogRead(Roll);
*pYaw = analogRead(Yaw);
Serial.print("Pitch: ");
Serial.print(*pPitch);
Serial.print("Roll: ");
Serial.print(*pRoll);
Serial.print("Yaw: ");
Serial.print(*pYaw);
setupTransmitter();
readJoysticks(&pitch, &roll, &yaw);
sendData(&pitch, &roll, &yaw);
Reciever Code
int pitch;
int roll;
int yaw;
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
void setupReciever()
radio.begin();
radio.openReadingPipe(1, Address);
radio.startListening();
Serial.println("Setup Reciever Done");
void recieveData(int *pPitch, int *pRoll, int *pYaw)
if (radio.available())
Serial.println("Listened");
radio.read(pPitch, sizeof(*pPitch));
radio.read(pRoll, sizeof(*pRoll));
radio.read(pYaw, sizeof(*pYaw));
Serial.println("Received Data : ");
Serial.print(pitch);
Serial.print(" Roll: ");
Serial.print(roll);
Serial.print(" Yaw: ");
Serial.print(yaw);
Serial.println("Not listening");
setupReciever();
recieveData(&pitch, &roll, &yaw);
You are using 3 writes to send the data and 3 reads to receive. That is not optimal. Put the 3 data points into an array or struct and send with 1 write and 1 receive on the other end.
Here is my (tested on real hardware) joystick send and receive code that uses a struct to send and receive the data from 2 joysticks. Adapt as necessary (mind the CE and CSN pins).
Sender code:
// joystick send by groundFungus aka c.goulding
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
const byte CE_PIN = 9;
const byte CSN_PIN = 10;
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
struct JoyValues
int joy1x;
int joy1y;
int joy2x;
int joy2y;
} joyValues;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
const byte joy1xPin = A0;
const byte joy1yPin = A1;
const byte joy2xPin = A2;
const byte joy2yPin = A3;
Serial.println("SimpleTx Starting");
radio.begin();
radio.setChannel(76); //76 library default
//RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH and RF24_PA_MAX
radio.setPALevel(RF24_PA_HIGH);
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3, 5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis)
send();
Serial.print("JOY 1 X = ");
Serial.print( joyValues.joy1x);
Serial.print(" JOY 1 Y = ");
Serial.print( joyValues.joy1y);
Serial.print(" JOY 2 X = ");
Serial.print( joyValues.joy2x);
Serial.print(" JOY 2 Y = ");
Serial.println( joyValues.joy2y);
prevMillis = millis();
void send()
joyValues.joy1x = analogRead(joy1xPin);
joyValues.joy1y = analogRead(joy1yPin);
joyValues.joy2x = analogRead(joy2xPin);
joyValues.joy2y = analogRead(joy2yPin);
radio.write( &joyValues, sizeof(joyValues) );
receiver code:
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
struct JoyValues
int joy1x;
int joy1y;
int joy2x;
int joy2y;
}joyValues;
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
getData();
showData();
void getData()
if ( radio.available() )
radio.read( &joyValues, sizeof(joyValues) );
newData = true;
void showData()
if (newData == true)
Serial.print("Data received >> ");
newData = false;
In Robin2's simple rf24 tutorial in post #30 there is a sketch to check the hardware connection between each radio module and its attached processor (Arduino). Run that sketch for each module and post the results.
How is each radio module powered? Post a schematic or wiring diagram.
Can you please post some images of your project?
So we can see your component layout.
These require a decent power supply, and some supply filtering to perform properly, especially the units with PA (Power Amplifier), fitted.
The higher power radios (external antenna) may not comminicate if too close together. Try moving them a few meters apart and/or reduce transmitter power.
Hi @TomGeorge,
You said about giving decent power supply and supply filtering at the moment the supply to it is from my PC and laptop. The receiver power supply will soon be switched into a 3 cell Li-Po battery
Thanks nuclear
Actually maybe true because when I first used the code you gave it worked perfectly then I changed the position of the modules maybe that is the problem
