error with void pin mode
So I am trying to make a line follower robot with simple code. Here is how far i have reached
int ir1 = A0;
int ir2 = A1;
int motor1 = 4;
int motor2 = 5;
int motor3 = 6;
int motor4 = 7;
  pinMode (ir1 = INPUT);
  pinMode (ir2= INPUT);
  pinMode (motor1 = OUTPUT);
  pinMode (motor2 = OUTPUT);
  pinMode (motor3 = OUTPUT);
  pinMode (motor4 = OUTPUT);
  if (ir1 = 1 && ir2 = 0)
    digitalWrite (4, 1);
    digitalWrite (5, 0);
    digitalWrite (6, 0);
    digitalWrite (7, 1);
  if (ir1 = 0 && ir2 = 1)
    digitalWrite (4, 0);
    digitalWrite (5, 1);
    digitalWrite (6, 1);
    digitalWrite (7, 0);
now it shows me an error saying too few arguments to function void pinMode
here is the message
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: “Arduino Nano, ATmega328P (Old Bootloader)”
C:\Users\Admin\Documents\Arduino\irlol\irlol.ino: In function ‘void setup()’:
irlol:11:23: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
In file included from sketch\irlol.ino.cpp:1:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:133:6: note: declared here
void pinMode(uint8_t, uint8_t);
irlol:12:22: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
irlol:13:27: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
irlol:14:27: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
irlol:15:27: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
irlol:16:27: error: too few arguments to function ‘void pinMode(uint8_t, uint8_t)’
C:\Users\Admin\Documents\Arduino\irlol\irlol.ino: In function ‘void loop()’:
irlol:21:22: error: lvalue required as left operand of assignment
irlol:28:22: error: lvalue required as left operand of assignment
exit status 1
requesting help asap. thank you
Have a look at the top of the page - Resources / Reference. You’ll find pinMode on that page and it will show you the correct syntax for using it. As the error says it wants 2 parameters, pin number and mode (no = sign).
And then in your ifs - = means assign a value, == means compare two things, which I guess is what you meant.
Programming languages are very fussy. You have to do things their way. You can’t just write whatever you feel like and expect the compiler to understand what you probably meant.
Steve
https://www.arduino.cc/en/Reference.PinMode
https://www.arduino.cc/reference/en/language/structure/control-structure/if/
Tom... :slight_smile:
slipstick:
Thank you very much. Im new to arduino and code and this totally slipped out of my mind.
