Error with WIFI.HPP when compiling Painless_Mesh code
This is the error message I get when I compile Examples->Painless Mesh->Basic
The error code comes from wifi.hpp in Painless_Mesh
\Documents\Arduino\basic_Mesh\basic_Mesh.ino:8:
c:\Users\XX\OneDrive\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp: In member function 'void painlessmesh::wifi::Mesh::init(TSTRING, TSTRING, uint16_t, wifi_mode_t, uint8_t, uint8_t, uint8_t)':
c:\Users\XX\OneDrive\Documents\Arduino\libraries\Painless_Mesh\src/arduino/wifi.hpp:49:10: error: 'class WiFiClass' has no member named 'setAutoConnect'; did you mean 'setAutoReconnect'?
49 | WiFi.setAutoConnect(false)); // Disable autoconnect
| setAutoReconnect
 * @param ssid The name of your mesh.  All nodes share same AP ssid. They are
   * distinguished by BSSID.
   * @param password Wifi password to your mesh.
   * @param port the TCP port that you want the mesh server to run on. Defaults
   * to 5555 if not specified.
   * @param connectMode Switch between WIFI_AP, WIFI_STA and WIFI_AP_STA
   * (default) mode
  void init(TSTRING ssid, TSTRING password, uint16_t port = 5555,
            WiFiMode_t connectMode = WIFI_AP_STA, uint8_t channel = 1,
            uint8_t hidden = 0, uint8_t maxconn = MAX_CONN) {
    using namespace logger;
    // Init random generator seed to generate delay variance
    randomSeed(millis());
    // Shut Wifi down and start with a blank slage
    if (WiFi.status() != WL_DISCONNECTED) WiFi.disconnect();
    Log(STARTUP, "init(): %d\n",
    WiFi.persistent(false);
    // start configuration
    if (!WiFi.mode(connectMode)) {
      Log(GENERAL, "WiFi.mode() false");
    _meshSSID = ssid;
    _meshPassword = password;
    _meshChannel = channel;
    _meshHidden = hidden;
    _meshMaxConn = maxconn;
