Error
I am trying to evaluate the and averaged analog input called averagelightLevel with the statement:
if (averagelightLevel >= 600)
(close)
and the message I get is ISO C++ forbids comparison between pointer and integer
What I want to happen is if averagelightLevel is >= 600 execute close
Assuming 'close' is a function, it should be called as:
close();
not:
(close)
In future, and now if that doesn't work you need to post your FULL code. A tiny snippet of code like that is pretty much useless when it comes to trying to debug.
The error seems pretty explicit, but we'd need to see your code.
redneck:
I guess that averagelightLevel is a function and you are trying to compare the return value from the function:
if (averagelightLevel() >=  600)
Of course, I shouldn't have to guess.
PeterH:
redneck:
Sorry guys, I read the read me for this catagory and it said something about short and sweet. I am trying to write some code for a automatic chicken door that will open and close depending on the light level and not rely on a real time clock with tables to operate. Please forgive my simple questions, it's my first attempt to program anything beyond a blinking light. Thanks for the help, that was the ticket!
It also said to post your code inside code tags, and to give a meaningful subject line.
