error
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_TMP007.h"
Adafruit_TMP007 tmp007;
Serial.println("Adafruit TMP007 Tdie vs Tobj");
if (! tmp007.begin()) {
Serial.println("No sensor found");
while (1);
float objt = tmp007.readObjTempC();
Serial.print("Object Temperature: "); Serial.print(objt); Serial.println("*C");
float caltemp = calibrate();
Serial.print("CALIBRATED Object Temperature: "); Serial.print(caltemp); Serial.println("*C");
float diet = tmp007.readDieTempC();
Serial.print("Die Temperature: "); Serial.print(diet); Serial.println("*C");
findSupplyVoltage();
delay(4000); // 4 seconds per reading for 16 samples per reading
float calibrate(){
//set up constants
float E = 0.971; //emissivity of human skin
float SBC = 5.7E-12; //stefan-boltzman constant
float S0 = E*SBC;
double A1 = 0.00175;
double A2 = –0.00001680;
float Tref = 25.0;
float vSensor = ((45.9 + 27.4)/20*(objt-20)) - 27.4;
float Vos = –0.00001178;
float S = S0*(1+A1*(diet-Tref) + A2*pow(diet - Tref , 2));
float fVobj = (vSensor - Vos);
float OBJTEMP = sqrt(sqrt(pow(diet , 4) + (fVobj / S ))); // calibrated temp of object
return OBJTEMP;
void findSupplyVoltage(){
int sensorVal = analogRead(A4);
Serial.print("sensorValue:"); Serial.println(sensorVal);
float Vsens = sensorVal * (5.0/1023.0);
Serial.print("sensorVoltage:"); Serial.println(Vsens);
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we're trying to read your code.
When your code requires a library that's not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
  double A2 = -0.00001680;
This will not compile because A1 and A2 are already declared as aliases for analogue pins 1 and 2
The error message is very explicit
Arduino: 1.5.6-r2 (Windows 7), Board: "Arduino Uno"
sketch_oct31b:1: error: conflicting declaration 'double A1'
C:\Program Files\Arduino\hardware\arduino\avr\variants\standard/pins_arduino.h:50: error: 'A1' has a previous declaration as 'const uint8_t A1'
  enabled in File > Preferences.
Note how I used code tags to present the code and errors better here
See read this before posting a programming question
