error
Couldn’t connect! Is the red led blinking? You may need to update the firmware with FWUpdater sketch
How solution this problem?
Something that know the solution…
Servo_test.ino (2.07 KB)
Try to upload the Flasher example (Arduino IDE > Files > Examples > Mkrmotor Carrier> Flasher). When it uploads, open the serial monitor. That should update the firmware I think. Then see if it works.
