Im getting this message: exit status 1 expected ‘}’ at end of input. Can someone help me please, Thanks in advance
My code:
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include <ir_Lego_PF_BitStreamEncoder.h>
#include <Stepper.h>
#include “Stepper.h”
#include “IRremote.h”
/----- Variables, Pins -----/
#define STEPS 32 // Number of steps per revolution of Internal shaft
int Steps2Take; // 2048 = 1 Revolution
int receiver = 6; // Signal Pin of IR receiver to Arduino Digital Pin 6
/-----( Declare objects )-----/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 10, 9, 11);
IRrecv irrecv(receiver); // create instance of ‘irrecv’
decode_results results; // create instance of ‘decode_results’
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) // have we received an IR signal?
switch(results.value)
case 0xFF629D: // UP button pressed
small_stepper.setSpeed(500); //Max seems to be 700
Steps2Take = 2048; // Rotate CW
small_stepper.step(Steps2Take);
delay(2000);
case 0xFFA857: // DOWN button pressed
Steps2Take = -2048; // Rotate CCW
delay(2000);
irrecv.resume(); // receive the next value
